Endyn pistons + 13k mi =
Old Apr 14, 2003 | 08:08 PM
bruthaboost's Avatar
Default Endyn pistons + 13k mi =
I'm using Endyn slugs (9.5:1) and I had my piston to wall clearance checked and double checked from a different source. Eh, call me overly cautious. Anywho, my compression is a consistant 185 across the board. Is this type of wear normal?
and a closer view
Old Apr 14, 2003 | 09:14 PM
intekragsr's Avatar
Default Re: Endyn pistons + 13k mi = (bruthaboost)
ttt, interested too....
Old Apr 14, 2003 | 09:25 PM
boosted hybrid's Avatar
Yes, its fairly normal. When you had the engine built did they utilize the cross hatch pattern on the cylinders? It looks like it still retains them. Anyway, the wear pattern looks to be even from the pictures.
Old Apr 14, 2003 | 09:27 PM
falcongsr's Avatar
What is this crap?
hey man
what rings were used with those pistons?
Old Apr 14, 2003 | 10:41 PM
B18EG6's Avatar
Default Re: Endyn pistons + 13k mi = (boosted hybrid)
What if wear is uneven, and the scratches cannot be snagged with the fingernail but you can def feel them with your finger? And what if compression was fairly uneffected?
still cause for worries?
Old Apr 14, 2003 | 10:49 PM
VaporTrail's Avatar
New User
looks aiight to me
Old Apr 14, 2003 | 11:25 PM
ImportReview
Guest
Posts: n/a
NO, that is not normal at all. It looks like the pistons heated up and expanded too close to the cylinder walls, scratching them.
Just ball hone it, smooth out the pistons and put the pistons back in, youll be fine.
Jeff
Old Apr 14, 2003 | 11:28 PM
SEFIxCivic's Avatar
doesnt look normal. if it was on the exhaust side, and you were making big power maybe. but the intake side doesn't usually exhibit that kind of wear.
Old Apr 15, 2003 | 03:23 AM
Joseph Davis's Avatar
Default Re: Endyn pistons + 13k mi = (SEFI8LOxCivic)
I have no experience with forgings, but any time I've popped off a head and seen vertical scratches like that, something needed to be shitcanned.
I ran with a busted ring land and huge plumes of smoke under boost for 10K miles due to a broken 30 degree section of ring land on the #1 cylinder. It didn't scratch up the cylinder wall that badly, probably due to how the ring land broke. PM illdesignzls if you don't believe me; I gave the block to him.
Old Apr 15, 2003 | 03:53 AM
Default Re: Endyn pistons + 13k mi = (J. Davis)
Hmmm. Various opinions here. Well, the wear patterning is even and a crosshatch pattern was used when the bore was honed. I don't know if you can tell from the picture, but the crosshatch is still visible even "under" the scratches.
The rings were supplied by Endyne as well.
BTW, the engine doesn't smoke.
Old Apr 15, 2003 | 04:17 AM
CRVRX's Avatar
That looks fine , You wil see a few fine scratches, the piston does fly up and down in there. If it doesn't smoke that tells you it's fine.
Old Apr 15, 2003 | 04:28 AM
MiraiZ's Avatar
Default Re: Endyn pistons + 13k mi = (CRVRX)
ask the man himself...send some pics to Larry...he's good about giving advice via e-mail
mike93eh2
Dec 14, 2010 02:34 PM
haroldthefly91crx
Jun 7, 2007 07:42 AM
Bspec18
Oct 4, 2005 03:11 PM
Mark
Aug 26, 2003 09:36 PM
greengangsta
Mar 18, 2002 07:23 PM
