Please Help!!! WHat are the signs of a D-16 Distributor going bad??
Old Apr 14, 2003 | 05:20 PM
97civicdx's Avatar
Default Please Help!!! WHat are the signs of a D-16 Distributor going bad??
I would like to know what the signs a distributor gives when it goes bad. Poor starting, sudden stalling while driving, car wont start at all?
My car has fuel, I need to check for spark when cranking but once I get the car turning over, it runs normally with some stalling/ sputtering. Once running, It does have spark, etc.
I did a diagnostic resistance test to the coil, the primary is a little high at .9 ohms and the secndary is 12.6, on the low end of the scale. Normal primary resistance should be between .6 and .7....
Old Apr 14, 2003 | 08:10 PM
SymphonyX's Avatar
Default Re: Please Help!!! WHat are the signs of a D-16 Distributor going bad?? (97civicdx)
when your car doesn't turn over. i have blown at least 8 of this on my b16 in less then 2 years. i know. cost too ******* much too. now i got msd blaster coil, that **** should never blow.
Old Apr 15, 2003 | 12:45 PM
97civicdx's Avatar
Default Re: Please Help!!! WHat are the signs of a D-16 Distributor going bad?? (SymphonyX)
If you push start the car, it will run normally right?
Old Apr 17, 2003 | 02:57 PM
97civicdx's Avatar
UGHHHHHHHHHHHHHH!
Found the cause!!!!!!!!
On the ignition coil, there is a tiny spring the is in contact with the cap. It got bent when I installed a new cap thereby causing bad contact to the coil. What out for this guys!!!!!!!!!!!!!
Old Apr 17, 2003 | 03:05 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">UGHHHHHHHHHHHHHH!
On the ignition coil, there is a tiny spring the is in contact with the cap. It got bent when I installed a new cap thereby causing bad contact to the coil. What out for this guys!!!!!!!!!!!!!</TD></TR></TABLE>
**** happens man
Old Apr 17, 2003 | 03:09 PM
IS3Fifty's Avatar
at least you figured out the problem.
torr
Apr 24, 2024 09:35 AM
sitinthehall
21
Oct 19, 2006 06:39 PM
ActiveAero
Sep 16, 2006 11:21 AM
erik92DA
Jun 8, 2006 08:16 PM
gsrvx
Jun 6, 2002 11:27 AM
