Idle and driveability problem
Old Apr 13, 2003 | 03:56 PM
Luke J's Avatar
Default Idle and driveability problem
Need help, my 91 CRXsi idles like ****, especially when cold.
-It idles at 1500 rpm, then drop's down to 800 and wants to die out, then back to 1500 etc...
-No power at low rpm, runs worse when cold.
What do you guys think, IAC valve, timing?
Old Apr 13, 2003 | 04:23 PM
Luke J's Avatar
Default Re: Idle and driveability problem (Lucky925l)
The car also runs very rich at idle
-thanks
Old Apr 14, 2003 | 11:50 AM
DJ_SaNdOz's Avatar
sounds like mine; but mine misses too & it's leaking oil/gas on the plugs-damn 12 year old gaskets. sorry, not anyhelp-but now you know that you're not alone.
Old Apr 16, 2003 | 10:13 PM
sabertooth's Avatar
take a look at ur fuel infectors
Old Apr 16, 2003 | 10:19 PM
thaiphob's Avatar
Nikon!!!
Default Re: (sabertooth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabertooth &raquo;</TD></TR><TR><TD CLASS="quote">take a look at ur fuel infectors</TD></TR></TABLE>
i think he means injectors
Old Apr 17, 2003 | 03:01 AM
ULTRA911's Avatar
Default Re: (thaiphob)
it could be your 'infectors', but do you have any codes? iacv do go out from time to time. check vacumn hoses since you said it goes up to 1500, then 800, then 1500, and somewhere it dies, sounds like a leak.
Old Apr 17, 2003 | 04:14 AM
tpr's Avatar
tpr
Check your TPS voltage it should be 0.45-0.5 vdc from the middle wire to the green and white wire. Also have you set the static idle. Warm it up then disconnect the IACV. The idle should be at around 750 RPM. Use the idle speed screw at the top rear of the throttle body to set it to 750 RPM. Reconnect the IACV and the problem should be solved. At least it fixed my erratic idle. If this does not do it it probably a vacuum leak. Spray carb cleaner on the hoses and fittings when the idle changes you have found your leak.
Old Apr 17, 2003 | 04:40 AM
Luke J's Avatar
Default Re: Idle and driveability problem (tpr)
THanks for the responses, I will check TP voltage later today. I know about the vacuum trick, but I don't think that's the problem.
-I will keep you posted........thanks
alghafat424
Nov 13, 2006 01:29 AM
lshatch92
21
Oct 28, 2005 06:38 PM
RedEK
Dec 1, 2004 06:55 PM
kihun_cha
25
Aug 5, 2004 09:49 PM
quikrpm'z
Jan 31, 2002 06:16 PM
