sway bar or tie bar?
I wanted to know which is better to get a rear sway bar or rear lower tie bar? Do they both do the samething? will they clear each other? someone please help me out. i have a 98 ex coupe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast »</TD></TR><TR><TD CLASS="quote">You will see more of a benefit from a sway bar. You can have both of them at the same time.</TD></TR></TABLE>
If you can only get one, then get the sway bar. It makes the bigger difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siqcivic »</TD></TR><TR><TD CLASS="quote">I wanted to know which is better to get a rear sway bar or rear lower tie bar? Do they both do the samething? will they clear each other? someone please help me out. i have a 98 ex coupe.</TD></TR></TABLE>
Don't buy either. I would recommend that you do some more reading to understand the difference between the 2 and how to choose the right one for your application. If you go to the road-racing forum, there is a sticky at the top with the forum rules. It has a list of links with more info that you ever wanted to know about suspensions...
lowRIDAH
Jul 12, 2004 10:43 PM
