sway bar or tie bar?
Old 04-13-2003, 02:51 PM
JMD
JMD's Avatar
Default sway bar or tie bar?
I wanted to know which is better to get a rear sway bar or rear lower tie bar? Do they both do the samething? will they clear each other? someone please help me out. i have a 98 ex coupe.
Old 04-13-2003, 02:57 PM
boostsohfast's Avatar
Default Re: sway bar or tie bar? (siqcivic)
You will see more of a benefit from a sway bar. You can have both of them at the same time.
Old 04-13-2003, 03:05 PM
joe_bocc's Avatar
Default Re: sway bar or tie bar? (boostsohfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">You will see more of a benefit from a sway bar. You can have both of them at the same time.</TD></TR></TABLE>
If you can only get one, then get the sway bar. It makes the bigger difference.
Old 04-13-2003, 03:11 PM
Default Re: sway bar or tie bar? (joe_bocc)
is that not what I just said?
Old 04-13-2003, 03:37 PM
Damon's Avatar
if you get a sway bar, rememeber to factor in for subframe reinforcement. Beaks is my personal recomendation.
Old 04-13-2003, 07:30 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siqcivic &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to know which is better to get a rear sway bar or rear lower tie bar? Do they both do the samething? will they clear each other? someone please help me out. i have a 98 ex coupe.</TD></TR></TABLE>
Don't buy either. I would recommend that you do some more reading to understand the difference between the 2 and how to choose the right one for your application. If you go to the road-racing forum, there is a sticky at the top with the forum rules. It has a list of links with more info that you ever wanted to know about suspensions...
team_exceed
04-11-2008 08:08 AM
RyanA
11
01-20-2008 10:04 PM
brian_98EK
09-08-2007 12:22 PM
SpoonKid
10-26-2006 11:05 AM
lowRIDAH
07-12-2004 10:43 PM
Quick Reply: sway bar or tie bar?
