i just boosted my h22 but...? need help
Old Apr 13, 2003 | 10:45 AM
booja's Avatar
Default i just boosted my h22 but...? need help
i have a 95 jdm h22a. i just turbo charged it yesterday. when i got it back there were somethings that i can't understand... my set up is:
95 jam h22a
t3/t4 turbo b trim
12:1 fmu
walbro intank pump
vafc
missing link
type s bov
turbonetics deltagate
everything else is stock
1. there's a 7psi spring in my wastegate but it won't boost any higher than 4-5psi
2. where do i set my vtec so it won't lag when it comes in
3. when i'm boosting my power noticably stops at 6.5k to 7 all the way to redline
4. i know i should get it on a dyno but is there anything i can do w/ the timing or set the fuel on the vafc to help it for now?
Old Apr 13, 2003 | 11:07 AM
98civicEX's Avatar
Default Re: i just boosted my h22 but...? need help (booja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booja &raquo;</TD></TR><TR><TD CLASS="quote">
4. i know i should get it on a dyno but is there anything i can do w/ the timing or set the fuel on the vafc to help it for now?</TD></TR></TABLE>
1. Check for any break in the intercooler piping, you may have a leak.
2. You'll just have to test and tune, it's different w/ every car.
3. I noticed you're running VAFC, fmu, and missing link. Ditch that get some bigger injectors 440/450's and start using the VAFC hack (serach VAFC hack)
4. General rule if using the VAFC hack is to retard the timing via distributor 2-3 degrees.
Old Apr 13, 2003 | 12:23 PM
romeo619romeo's Avatar
Default Re: i just boosted my h22 but...? need help (98civicEX)
running to lean
teamitr
Mar 16, 2005 10:18 PM
turboH22Aakkord
Aug 26, 2004 08:49 AM
gen4h22a
Aug 12, 2004 01:12 PM
racinskittle
Jul 18, 2003 08:53 PM
b18bvudoo
Jul 18, 2002 03:50 PM
