max boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCitTOme »</TD></TR><TR><TD CLASS="quote"> stock</TD></TR></TABLE>
It all depends on your fuel setup. With a set of 450's and an SMC/VAFC, I wouldn't go over 8psi. With a decent "stand-alone" you could easily crank it up to 14psi.
so yeah, if you want to go cheap, retard the timming a few degrees, find a Vortech FMU on e-bay or something, and boost 5-6 psi. but make sure you have the right kind of turbo, like for example a Garett T3/TO4E. Your not going to want a smaller turbo cause a higher compression engine like yours is going to rely on a greater mass of air, so make sure you keep that in mind.
btw, if your interested, check out the turbo here:
https://honda-tech.com/zerothread?id=468082
one slow coupe
Mar 19, 2006 05:52 PM
Wrath of VTEC
Sep 15, 2003 06:58 PM
