Water Temperature Gauge Install?
Old Apr 12, 2003 | 08:46 AM
Alpha_GSR's Avatar
Default Water Temperature Gauge Install?
It's an Autometer Electrical unit. My question is where did you guys install the sending unit and what parts are needed?
Kong
Old Apr 12, 2003 | 12:36 PM
sgT's Avatar
sgT
Default Re: Water Temperature Gauge Install? (Alpha_GSR)
upper radiator neck in the cylinder head.
Old Apr 12, 2003 | 01:15 PM
2lowintegra's Avatar
Default Re: Water Temperature Gauge Install? (sgT)
just get a t-fitting from a local plumbing store, and cut out a section from your rad hose, then put the t fitting in there, and screw the copper wire from the water temp gauge into it, then use a couple of clamps and some silicon tape and BAM, you're done, make sure it doesn't leak
Old Apr 12, 2003 | 05:28 PM
Alpha_GSR's Avatar
any pictures and parts that are required?
Kong
Old Apr 28, 2003 | 03:27 PM
Screamer's Avatar
Some pics would be good please......
Old Apr 28, 2003 | 03:47 PM
Default Re: Water Temperature Gauge Install? (Screamer)
i'll post up some pics later tonight
Old Apr 29, 2003 | 07:14 AM
Screamer's Avatar
Default Re: Water Temperature Gauge Install? (2lowintegra)
Thanks, I'll keep on checking back.
Old May 14, 2003 | 06:52 AM
Fuster_Cluck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screamer &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I'll keep on checking back.
Bump!
I'm interested to see the pics as well. This is one of the gauges I will be installing in my Hybrid
Thanks!
Old May 14, 2003 | 07:22 AM
Philly_NBP_R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lowintegra &raquo;</TD></TR><TR><TD CLASS="quote">just get a t-fitting from a local plumbing store, and cut out a section from your rad hose, then put the t fitting in there, and screw the copper wire from the water temp gauge into it, then use a couple of clamps and some silicon tape and BAM, you're done, make sure it doesn't leak</TD></TR></TABLE>
um, I never added this gauge before, but wouldn't this give you an inaccurate reading? You would only have an accurate reading if the thermostat was open... Might want to mount it somewhere where it will ALWAYS give a correct reading.
Old May 14, 2003 | 07:14 PM
Default Re: Water Temperature Gauge Install? (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">
um, I never added this gauge before, but wouldn't this give you an inaccurate reading? You would only have an accurate reading if the thermostat was open... Might want to mount it somewhere where it will ALWAYS give a correct reading.</TD></TR></TABLE>
It would just be like the temp. needle on most clusters. After 2-3 minutes the needle moves up on the temp. gauge.
Old May 14, 2003 | 10:59 PM
Alpha_GSR's Avatar
Default Re: Water Temperature Gauge Install? (Hybrid93Hatch)
Come on guys, all this time and we still don't have a picture? Give us wannabe-techs here a chance.
Old May 15, 2003 | 05:55 AM
CHEETAH's Avatar
you have to tell us the year of your cylinder head and I'll tell you where to install it, some years like 94/95 gsr has an ideal spot for the sending unit while ITRs and B16a coolant neck really suck.
The easiest way to install, is to tee off one of the 3/8" coolant hoses and clamp on the sender unit onto one end of the hose.
greg
Old May 15, 2003 | 06:34 AM
Default Re: Water Temperature Gauge Install? (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">you have to tell us the year of your cylinder head and I'll tell you where to install it, some years like 94/95 gsr has an ideal spot for the sending unit while ITRs and B16a coolant neck really suck.
greg</TD></TR></TABLE>
I have a 98 GSR, thanks
Old May 15, 2003 | 07:20 AM
Screamer's Avatar
I have a 98 ITR
Old May 15, 2003 | 08:28 AM
Alpha_GSR's Avatar
94' GSR head
90efSI
Feb 10, 2006 04:26 PM
93_hatch
May 2, 2004 12:49 PM
S@nt0s
Dec 1, 2003 03:23 PM
monicle
May 27, 2003 10:41 AM
Wide Open Throttle
May 26, 2002 07:38 PM
