One of those ANNOYING which is better ?'s. Between T3 and 14b turbo.
Old Apr 10, 2003 | 08:51 PM
racinskittle's Avatar
Default One of those ANNOYING which is better ?'s. Between T3 and 14b turbo.
I will be turboing my d16z6 pretty soon and I am wondering which turbo I should get. I want a good drag turbo that will hold boost all the way to redline. Will both the 14b and T3 turbo do this?
My goal is about 10psi. Will both these turbos hold this boost to redline? I have a T25 now that i am going to sell because I know it doesn't. Which one flows better as well?
**OH! will both of these turbos work with the HF manifold as well?
Which one of these will be the most cost effective as well? and which will be the easiest to do?
Thanks for the replies.
Modified by racinskittle at 6:20 AM 4/11/2003
Old Apr 10, 2003 | 08:54 PM
turbod16y8's Avatar
Default Re: One of those ANNOYING which is better ?'s. Between T3 and 14b turbo. (racinskittle)
ok the easiest and most cost effective is the 14b. thats what im using right now. and it will fit the hf maanifold with an adapter plate. holds boost all the way to redline.
Modified by turbod16y8 at 10:26 PM 4/10/2003
Old Apr 10, 2003 | 09:24 PM
Default Re: One of those ANNOYING which is better ?'s. Between T3 and 14b turbo. (turbod16y8)
ok great thanks. That's the easiest to get as well Just out of curiosity what are you boosting? Also, is the downpiping difficult to do? You mean cost effective right?
Thanks again.
Dan
Old Apr 10, 2003 | 09:27 PM
turbod16y8's Avatar
yea thats what i meant. im boosting 8 psi right now. heres a link to my setup
https://honda-tech.com/zerothread?id=452190
knightsef-eg
May 2, 2010 07:48 PM
slows2k
Dec 25, 2005 05:19 PM
mrx
May 12, 2004 11:20 AM
LOwrestling2001
Nov 27, 2002 09:59 AM
