reducing boost
Old Apr 10, 2003 | 06:10 PM
stockgreencivic's Avatar
Default reducing boost
i have a 14b turbo and wondering how to reduce boost. i think stock wastegate is around 8psi, but would like to run ~5 for now. i was reading you can extend the arm on the actuator, but i can't find that post anymore. Anyone?
Old Apr 10, 2003 | 06:12 PM
dfoxengr's Avatar
Default Re: reducing boost (stockgreencivic)
u can get a boost controller
Old Apr 10, 2003 | 06:14 PM
Default Re: reducing boost (hybridvteceg)
ok thanks,, i was under the impression a boost controller only increased boost. So boost controllers can be set from 1psi-up?
Old Apr 10, 2003 | 06:16 PM
dfoxengr's Avatar
yeah...basically. make our own.. http://www.c-speedracing.com
theres also a few posts here about them right now on the 1st page./..
Old Apr 10, 2003 | 06:20 PM
2kturboex's Avatar
FYI a boost controller will not go below set wastegate pressure
Old Apr 10, 2003 | 06:30 PM
Default Re: reducing boost (2kturboex)
so it can't be set below the wg pressure?? then back to original q. - how can boost be set lower then stock wastegate pressure?
Old Apr 10, 2003 | 06:33 PM
2kturboex's Avatar
I cant remember off had which way it need to be turned but you can take the rod from the acuator to the waste gate and either thread it in or out to increase decrease boost
Old Apr 10, 2003 | 06:41 PM
ridnmyhonda's Avatar
boost controllers can not be turned down...only up...sounds like you have an internal wastegate i think you spun it towards you too turn down boost (which ever way closes it more) good luck
Old Apr 10, 2003 | 07:28 PM
T3's Avatar
T3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kturboex &raquo;</TD></TR><TR><TD CLASS="quote">FYI a boost controller will not go below set wastegate pressure</TD></TR></TABLE>
Guess my 14.5psi spring is out of the question.
Old Apr 10, 2003 | 07:32 PM
Default Re: reducing boost (ridnmyhonda)
ok,, so all i have to do is spin the acuator --&gt; wastegate connector to turn down boost? as easy as that? off a dsm 1g 14b turbo
yah 14.5 spring is about 10 psi too high for me
b20vtech
Jan 24, 2008 05:55 PM
BlUAc
May 20, 2006 09:43 AM
builtboostedteg
Apr 5, 2006 05:19 PM
avsrule414
Dec 10, 2005 09:07 AM
clean
Oct 18, 2001 11:16 AM
