bizzar leakdown test question
Old Apr 10, 2003 | 02:47 PM
google's Avatar
Default bizzar leakdown test question
check this out guys. i did a leakdown test on my friends car. the motor was at TDC without a doubt. it came back 12%. so we turned the crank a little it went to 7%. what is that about. i mean is the motor not at tdc. when we turned it the cam was off at least 2 teeth. Any suggestions what was going on.
also did a compression test after. 225 220 220 225.... any help
Old Apr 10, 2003 | 03:40 PM
ScottEK's Avatar
Default Re: bizzar leakdown test question (1320in11)
What kind of compression numbers are you looking for that 220's aren't good enought?
Old Apr 10, 2003 | 03:58 PM
slomofo's Avatar
GDD Member
Make sure it's on the compression stroke, put a screwdriver in the spark plug hole to ensure that you're at TDC.
Old Apr 10, 2003 | 11:23 PM
google's Avatar
Default Re: bizzar leakdown test question (slomofo)
see thats whats not making any sense the compression is there. but where is the 12 % tp 8% coming from. I mean these are total seal rings it should be 0-2% or something like that. So could it be valves/seals/guides etc... misshaped or unshaped bowls. lost over hereeee
Old Apr 10, 2003 | 11:28 PM
google's Avatar
one more thing how much for the METRO R....
Old Apr 11, 2003 | 08:03 AM
google's Avatar
ttt
Old Apr 11, 2003 | 11:42 AM
psi420's Avatar
No disrespect, but total seal rings suck ***!
How many miles on the rings?
Old Apr 12, 2003 | 08:40 PM
Quick 200k Mile Motor's Avatar
in neutral, the piston is definately at TDC if the compressed air doesn't turn the motor over
humboldt_skim
May 31, 2008 08:18 AM
sinister357
Aug 25, 2007 10:05 PM
Sport_Injected
Aug 25, 2004 09:21 PM
EF8_SiR
Jul 20, 2003 10:24 PM
Propulsion
Jun 5, 2002 11:48 PM
