removing throttle position sensor
Old Apr 9, 2003 | 02:18 PM
rasta420's Avatar
Default removing throttle position sensor
how do you remove it? i have a d16a6 off of a 90 crx si. the two screws on the sides of the TPS doesnt have a hole for a screwdriver nor a hex shaped head.
also, when you install a new TPS, do you have to readjust it?
thanks
Old Apr 9, 2003 | 02:20 PM
EL Vap133's Avatar
Default Re: removing throttle position sensor (rasta420)
The TPS is riveted on, you're gonna have to break the rivets off, or just get a whole new TB....
Old Apr 9, 2003 | 02:25 PM
elpermgrande's Avatar
Default Re: removing throttle position sensor (Vap133)
get a dremel or other cutting tool,even a drill will work,cut a groove into the heads and the rivets are actually screws they just unscrew.super easy just be careful the TPS breaks easily if you are rough.
Old Apr 9, 2003 | 06:32 PM
gringo7718's Avatar
Default Re: removing throttle position sensor (elpermgrande)
a hammer and chisel work well when getting the old sensor off. but be careful
Old Apr 9, 2003 | 06:36 PM
uneek4dr's Avatar
Default Re: removing throttle position sensor (gringo7718)
yah break it with a hammer real smart idea.
Use a dremel or something to cut a slot in the center of those round headed things. They are actually screws and will just unscrew once you cut the slot for the screwdriver. make sure you cut the groove deep though or else you will not be able to get enough of the screwdriver tip in it to get the screw loose.
Old Apr 9, 2003 | 07:39 PM
Outsane's Avatar
If its one a good throttle body don't take it off...
Just take off the entire throttle body as one peice..
'then you won't have to adjust it when you put it back on.. (SO yes it does have to be adjusted if you take it off..)
Old Apr 10, 2003 | 01:52 PM
MAD SCIENTIST's Avatar
your all wrong haha i know how to do it nah nah.there not rivits boneheads.there breakoff screws.once there torqued the head beaks off.is everybody ready?get a hacksaw or dremil out make a slot then unscrew it.im a trained honda tech i know boutr this stuff.if you dont believe me look at the other side of your so called rivets see the treads last time i checked there r no treads on rivets.know u know and knowing i half the battle
Default Re: removing throttle position sensor (MAD SCIENTIST)
bump cause im right
Old Apr 10, 2003 | 01:53 PM
bump so everyone knows this
Old Apr 10, 2003 | 02:36 PM
rioninja's Avatar
bump,
because i'm also tired of people advising others to "break them" or "chissel them off".
Old Apr 10, 2003 | 02:39 PM
uneek4dr's Avatar
your avatar is very fitting. is it a self pic?
Incase YOU CANT READ two other people, one being myself, already answered this question for him. next time try not to be such as ***
Old Apr 10, 2003 | 04:13 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SCIENTIST &raquo;</TD></TR><TR><TD CLASS="quote">your all wrong haha i know how to do it nah nah.there not rivits boneheads.there breakoff screws.once there torqued the head beaks off.is everybody ready?get a hacksaw or dremil out make a slot then unscrew it.im a trained honda tech i know boutr this stuff.if you dont believe me look at the other side of your so called rivets see the treads last time i checked there r no treads on rivets.know u know and knowing i half the battle</TD></TR></TABLE>
At least we can spell....
Old Apr 10, 2003 | 05:03 PM
uneek4dr's Avatar
if the spelling is that bad i dont think i want his hands on my engine
Old Apr 10, 2003 | 09:07 PM
rasta420's Avatar
Default Re: removing throttle position sensor (uneek4dr)
alright, thanks everyone for your help. i used a hacksaw to cut a slot, and i got the TPS off. only thing was, while transferring the TPS to the other throttle body, the gasket broke off. i called honda to see if they sold that gasket, but they only sell it with the throttle body and TPS all as one piece. well i got it all back together for now since i need to drive around, but the idle fluctuates a little bit, about +-200 rpms. would the missing gasket be the cause of this? how can i make a gasket for the tps?
thanks
p.s. - the throttle body i bought didnt come with a TPS so thats why im transferring the TPS.
p.p.s. - when i first put the throttle body on, i adjusted idle by the idle screw, but now its back up around 1100 rpms. is the idle screw the right way to adjust idle?
Old Apr 10, 2003 | 09:12 PM
uneek4dr's Avatar
did you make sure when you put the sensor back on it was adjusted right? you know it can be moved back and forth and when you push the throttle it could have some play or it could have the sensor opened a little already....its hard to explain easier if i take pic sbut im to lazy haha. if you dont have the sensore adjusted right you cant open your car to full throttle and if its set to far forward it willl read as the throttle being open some already....understand?
Old Apr 10, 2003 | 09:23 PM
rasta420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr &raquo;</TD></TR><TR><TD CLASS="quote">did you make sure when you put the sensor back on it was adjusted right? you know it can be moved back and forth and when you push the throttle it could have some play or it could have the sensor opened a little already....its hard to explain easier if i take pic sbut im to lazy haha. if you dont have the sensore adjusted right you cant open your car to full throttle and if its set to far forward it willl read as the throttle being open some already....understand?</TD></TR></TABLE>
i think i adjusted it right. basically i kept the two screws loose, then started the car. it was revving really high around 4K, so i turned the TPS all the way til the idle went to about 800rpms, then i adjusted the idle screw to about 700 rpms. id rather have idle right then not being able to open the throttle all the way.
but still - is that gasket necessary? is that whats causing the idle fluctuation?
Old Apr 10, 2003 | 09:28 PM
uneek4dr's Avatar
i dont think so.......not sure what it could be.....
Old Apr 11, 2003 | 02:24 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr &raquo;</TD></TR><TR><TD CLASS="quote">if the spelling is that bad i dont think i want his hands on my engine </TD></TR></TABLE>
LOL!!
polything
23
Jul 27, 2012 08:23 AM
DCxMagus
May 3, 2007 06:45 AM
cazper8890
Mar 2, 2007 08:25 PM
seelyd
Feb 5, 2007 10:01 AM
ninjaman
Jul 21, 2003 01:02 PM
