Need help removing TPS (throttle position sensor)
Old Aug 8, 2001 | 03:16 PM
ninjaman's Avatar
New User
Default Need help removing TPS (throttle position sensor)
I just got a new TB and it's TPS is bad, so I want to use my old TB TPS. This is probably a lame question, but how do I get the TPS off. It doesn't have a phillips screw like the mass air sensor and I don't want to break it fiddling around. Thanks.
Old Aug 8, 2001 | 04:30 PM
jdmotorsports's Avatar
Default Re: Need help removing TPS (ninjaman)
easy...get yourself a dremmel cut-off wheel. put a nice deep notch into the tops of the screws..and use a flat head to remove it. good luck
Old Jul 21, 2003 | 01:02 PM
luckypon7's Avatar
Default Re: Need help removing TPS (jdmotorsports)
what kind off screw is it held on with?
polything
23
Jul 27, 2012 08:23 AM
cryingsuns
Mar 20, 2011 01:13 PM
dblock8989
May 15, 2009 01:54 PM
seelyd
Feb 5, 2007 10:01 AM
haroldthefly91crx
Oct 15, 2006 11:24 AM
