Transmission Drain and Fill plug?
I figured it's time to change my tranny oil now. Just wondering on the B16A, where are the 2 plugs located? I've never taken a look down there yet...hehe. Is it the same on teh b16 as with the d16?
The fill plug is on the left side of the passenger side axle. The drain plug is underneath the same axle. You should be able to fit a 3/8 drive socket into the drain plug.
here's the fill plug
And here's the drain
http://www.imagestation.com/pi...g.jpg
I hope that helps. Plug's are on the left side of the passengers side axels, look towards the lowest part of the tranny, your going to need a 1/4 drive and a 17 mm. Make some sort of tubing so that you can fill your tranny
Modified by Ninja_Jc7 at 3:03 PM 5/21/2003
Andrew14
21
Jun 28, 2010 01:12 PM
VtecAdvantage
Mar 30, 2010 10:10 PM
