del sol seats, what rails should i use???
They are going into my 95 coupe, but i was wondering about fitment. what are the benifits of using the del sol rails vs civic rails??? any input is appriciated
you have to mix and match with your Civic rails...I forgot exactly which one....
but one side all you need is the slide rail, and I BELIEVE on this seat belt side, you;ll need the whole bracket.
I have a 00 civic and had to use both civic rails on the Del Sol seats to make them work. I think the mix & match is for Integra seats/rails in the civic.
I just did this a month ago.....WAIT-
it's the outside bracket which has the seat adjuster lever...you need to swap the COMPLETE bracket on that side....and just the slider(3 bolts/nut") that bolts to the bracket on the inside of the seat
i just took the rails and sliders from my civic seats and put them on the del sol seats. everything lines up perfectly! should take you no more than 30 minutes.
hushypushy
Dec 29, 2008 09:19 PM
DC*whore
23
Feb 1, 2006 12:58 PM
RusBear
21
Jul 30, 2004 06:36 PM
