LS vtec turbo piston compression ration?
Old Apr 8, 2003 | 02:39 PM
x2gold's Avatar
Default LS vtec turbo piston compression ratio?
I was wondering what the best compression ration would be for an LS vtec turbo application. The block is a non-vtec B18B1 with a GSR head. The turbo is a t/3 with .42 / .48. How high of a ration can you run on pump gas? And how hight would you want it - with the turbo. Thanks
[Modified by x2gold, 6:48 PM 4/8/2003]
[Modified by x2gold, 6:49 PM 4/8/2003]
Old Apr 8, 2003 | 02:56 PM
dfoxengr's Avatar
Default Re: LS vtec turbo piston compression ratio? (x2gold)
9.0:1- ideal
Old Apr 8, 2003 | 03:14 PM
x2gold's Avatar
Default Re: LS vtec turbo piston compression ratio? (hybridvteceg)
JE forged recommended ? Would running something lower than 9.0 allow me to put more air into the cylinders and help the turbo at higher boost levels - assuming the exhuast is opened to accomodate. Thanks again.
dfoxengr's Avatar
JE is good, i would run 9. thats best..
different theories but 9 is good all around...
ppiart
Oct 20, 2011 09:16 AM
the.hamburglar
May 25, 2006 10:52 AM
1BadDC2
Aug 26, 2003 08:43 PM
xxxxspdrcr
Jul 26, 2003 12:32 PM
