Ls/vtec turbo
Old Jul 20, 2003 | 05:33 PM
xxxxspdrcr's Avatar
Default Ls/vtec turbo
How many of you are runnin ls/vtec turbo? how much psi are you pushin??? what are your dyno #'s lookin like? and what size of turbo?? im was running n/a ls/vtec but i just ripped apart my block and im putting low compression pistons and forged rods in... Just had my darton sleeves installed... Also I will probabally keep spraying to help get rid of the turbo lag... Just want to see some other ls/vtec turbo set up's...
Old Jul 20, 2003 | 06:41 PM
Turbocivic94's Avatar
Default Re: Ls/vtec turbo (xxxxspdrcr)
I got built ls/vtec turbo. I plan on running up to 25 psi to get the power I want. whatever it takes to make over 450hp. running t3/t4e
Old Jul 20, 2003 | 07:38 PM
xxxxspdrcr's Avatar
Default Re: Ls/vtec turbo (25 PSI CRX)
yeah thats what im talkin about... i want to boost 25+ psi also..
Old Jul 21, 2003 | 04:37 AM
xxxxspdrcr's Avatar
bump for the morning, wanna hear about the bad *** ls/vtec turbo motha phuckas in here...
Old Jul 21, 2003 | 05:15 AM
Boost2NA's Avatar
Default Re: (xxxxspdrcr)
see sig below. those numbers were made on a ls-vtec turbo set up. For entire set up click on the link in my sig.
Old Jul 22, 2003 | 12:42 PM
xxxxspdrcr's Avatar
bump for some dirty ho's
Old Jul 23, 2003 | 05:53 PM
agturbo's Avatar
Im running the LS-Vtec Turbo set up, we are in the process of tuning it right now, im running a 9:1 compression which i should have not done, but i had the motor built a while back, hopefully well have some good numbers, check my site for the specs
Old Jul 26, 2003 | 12:32 PM
untitled's Avatar
Default Re: (agturbo)
i am building a lsvtec right now. i will have the pr4 pistons in it which will make the compression around 9.5:1 i think thats right. any way its a basic rebuild with ACL bearing ARP head and rod bolts reconditioned rods. i was thinking with the appropriate wmount of fuel i hould hae no prolem with 12psi. ive never had a FI car but i have read up on it alot. 12psi out of a 14b and a log mani with full 3" ahould give me around 275-300? what do you guys think?
djxtreme808
Apr 14, 2009 04:46 AM
SupraRXZ
Dec 5, 2005 10:56 PM
Keangdawizes
Jun 9, 2005 05:50 PM
my ride
Apr 21, 2004 01:28 PM
KCDelSol
Feb 5, 2004 12:09 PM
