fuel light doesnt go on anymore..
Old Apr 8, 2003 | 12:28 AM
ILOVEGIRLS's Avatar
Default fuel light doesnt go on anymore..
my low fuel light doesnt go on anymore.. what can be the problem?
Old Apr 8, 2003 | 12:31 AM
Trac226's Avatar
Default Re: fuel light doesnt go on anymore.. (ILOVEGIRLS)
It could just be that the bulb is burned, I have one off a da if you'd want it, check the part #.
Old Apr 8, 2003 | 04:33 AM
ph0en1x's Avatar
I have the same problem on my 98 LS. I have checked the bulb and it is still good, what else could be the problem?
Old Apr 8, 2003 | 02:47 PM
ILOVEGIRLS's Avatar
Default Re: fuel light doesnt go on anymore.. (ph0en1x)
bump for us folk with no fuel light..
Old Apr 9, 2003 | 04:20 AM
JimBlake's Avatar
If the bulb is OK, then you go back to the sender in the gas tank. Unplug it, get a Helms manual to see which wires to jumper; if that turns on the light then your wiring is OK. That leaves the sender itself. Take it out of the tank & check it out with a DMM.
Old Apr 9, 2003 | 07:30 AM
crazy eyez killa
Guest
Posts: n/a
Maybe you're not out of fuel yet. Keep driving to confirm.
Old Apr 9, 2003 | 07:35 AM
-BlueGSR-'s Avatar
Default Re: fuel light doesnt go on anymore.. (BrianDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you're not out of fuel yet. Keep driving to confirm.
Thats what I did when I though mine was out..haha
It worked...b4 it used to go one when it was a 1/4 left..now it goes on only when its the very last drop!
Old Apr 9, 2003 | 01:28 PM
GSRacer1's Avatar
Default Re: fuel light doesnt go on anymore.. (KURRRRRWA!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRRRWA! &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you're not out of fuel yet. Keep driving to confirm.
and get stuck in the middle of nowhere
i fill the tank up every four days just in case the bulb actually is burnt
Old Apr 11, 2003 | 01:20 AM
ILOVEGIRLS's Avatar
Default Re: fuel light doesnt go on anymore.. (JimBlake)
is it easy to take out the sender? is that what makes the light goes on..i alway thought it was some kind of floating thing in there.
Atauto
Honda CR-V & Element
Aug 2, 2015 02:25 PM
Atauto
Apr 5, 2015 11:54 PM
Nbboy7
Jan 10, 2008 12:41 PM
civic_speed99
13
Jul 26, 2004 03:12 PM
