JDM D15B Studdering at 4000rpm????Help?????
Thought it was the timing and tried to move the dist. around a bit, but no luck. When the vtec kicks in it starts sputtering almost two wher it sounds like constant backfiring??? It started after I replaced the old dist because of a bad bearing.
ok i have the same motor and lets go thru all the steps....to me sounds like timing prob...ok..did the distributor come with car??? if yes or no replalce ignitor and cap and rotor if u havnt already...also make sure u have all connection like vtec and running a vtec ecu...preferably a p28...reaplce all spark plugs....my ignitor and coil inside were toast so replace it all just to be sure its not the distributor...also is it a vtec distributor?
constant backfiring seems like fuel cut to me? i don't know though mang
ok does the engine run fine at idle???...and make sure the timing is set correctly....having it too advanced or too retarded will get u that rev cut sound
The motor runs perfectly at idle, but as soon as you rev it around 3800, it starts sputtering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch »</TD></TR><TR><TD CLASS="quote">The motor runs perfectly at idle, but as soon as you rev it around 3800, it starts sputtering.</TD></TR></TABLE>
ignition problems....id just check your wires and plugs.
________
Buy Glass Bongs
________
Buy Glass Bongs
What is the crank angle sensor?
It isn't the plugs or wires, I checked.
If it is the fuel lines, where should I begin to check?
JDM_HNIC
24
Jul 13, 2011 08:47 AM
jim1980
Mar 11, 2010 12:06 PM
