What tool do I need to remove 02 sensor?
Old Apr 7, 2003 | 07:00 PM
mickey513's Avatar
Default What tool do I need to remove 02 sensor?
Is there a special tool or something that I need to remove the 02 sensor on the cat. converter? A special wrench or something?
Old Apr 7, 2003 | 07:01 PM
acatak's Avatar
Default Re: What tool do I need to remove 02 sensor? (mickey513)
NOPE... i believe it is 23 mm
Old Apr 7, 2003 | 08:03 PM
racin-type's Avatar
Default Re: What tool do I need to remove 02 sensor? (acatak)
when i ran over a fireheidrent wit my prelude the mechanic had to use a special tool that had an opening on the top to fit over the sensor. iono bout ur case.
Old Apr 7, 2003 | 08:09 PM
JDubya's Avatar
Default Re: What tool do I need to remove 02 sensor? (racin-type)
just use an open ended wrench. Its like 23mm or something, its prety big.
Old Apr 7, 2003 | 08:28 PM
IN VTEC's Avatar
22mm open-end wrench, although if you can get the closed-end over it, that's even better to use. 6pt is better than 12pt in this case, but not necessary.
I don't recommend using an oxygen sensor socket b/c the socket is difficult to keep seated properly while trying to bust it loose.
[Modified by IN VTEC, 11:28 PM 4/7/2003]
Old Apr 7, 2003 | 10:58 PM
mickey513's Avatar
Default Re: What tool do I need to remove 02 sensor? (IN VTEC)
So is it a 22mm or 23mm?
Old Apr 7, 2003 | 11:02 PM
IN VTEC's Avatar
I don't even own a 23mm box wrench or anything beyond 19mm (except that 22mm). I remember that 22mm is the size I used for the oxygen sensor and tie rod jam nuts.
[Modified by IN VTEC, 2:03 AM 4/8/2003]
Old Apr 7, 2003 | 11:28 PM
Sukebei Oni's Avatar
all of the oxygen sensors i have pulled out were 22mm and the backpressure tester i use has a 22mm fitting on it. i don't know exactly for your application, but i say to go with the 22mm.
Old Apr 8, 2003 | 12:25 AM
riceball777's Avatar
its a 22m
Old Apr 8, 2003 | 12:40 AM
The-LS's Avatar
theres a special socket for the O2 sensor, not neccessary but convenient. Like the other guy said, you probably want to bust is loose with something else first tho.
Old Apr 8, 2003 | 12:57 AM
brinks's Avatar
O2 sensor socket and impact gun. I tried that wrench crap and the thing wouldnt budge.
Old Apr 8, 2003 | 06:52 AM
Rory Breaker's Avatar
Soak the SOB with PB/WD40 and go to town with a wrench. Slide a pipe over it if you need the leverage...leverage is key.
Old Apr 8, 2003 | 08:52 AM
IN VTEC's Avatar
Default Re: What tool do I need to remove 02 sensor? (newgsrdriver)
I just bang the wrench with a sledgehammer to break it loose.
Old Apr 8, 2003 | 10:20 AM
EL Vap133's Avatar
I just used a crescent wrench...
Old Apr 8, 2003 | 02:01 PM
mickey513's Avatar
Default Re: What tool do I need to remove 02 sensor? (Vap133)
So I guess the dam thing is pretty tightly held down. I don't have access to a impact guy, that's for sure. Would a pipe work, if I put the wrench int he pipe and then go to loosen it up?
Old Apr 8, 2003 | 02:25 PM
sa21199's Avatar
thats what i did. And its a 22mm
Old Apr 8, 2003 | 04:10 PM
EL Vap133's Avatar
That'll work, do you not have access to tools?
Old Apr 8, 2003 | 04:18 PM
mickey513's Avatar
Got the basic wrench, sockets, pliers...
Old Apr 9, 2003 | 04:26 AM
JimBlake's Avatar
I just use a box-end wrench, after soaking in PBblaster. I've got the socket, but its harder to use because there's no room. There's barely enough room to feed the wire thru the opening of the wrench. Sometimes they're easier to get out if they're good & hot from driving.
kwengca
May 10, 2010 10:27 PM
Dokta
Mar 26, 2005 12:55 AM
JDMDC5888
Mar 25, 2004 02:36 PM
neilff
Jun 10, 2003 08:29 PM
B2FiNiTY
Jun 21, 2002 02:07 PM
