How do I remove the 02 sensor?
Old Jun 21, 2002 | 12:22 PM
B2FiNiTY's Avatar
Default How do I remove the 02 sensor?
Installing a header and cat, I have no idea how to remove the 02 sensor? Can someone please help? Thanks.
Old Jun 21, 2002 | 12:25 PM
Tweakmeister's Avatar
Default Re: How do I remove the 02 sensor? (B2FiNiTY)
you can buy a special Snap-On socket fitting that is slotted for the wires....or just use a wrench.
Basically first you disconnect the sensor from the wiring. There is a plastic snap type thing that you unhook it from. Drop the header and then unscrew the sensor once it's away from the car.
Old Jun 21, 2002 | 12:30 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: How do I remove the 02 sensor? (Tweakmeister)
I used the socket fitting at it was real easy
Old Jun 21, 2002 | 12:32 PM
yeah and to make things easier try to get some PB or similar rust penetration fluid (I like PB a lot!) and soak it. WD40 doesn't really do what PB can.
Old Jun 21, 2002 | 12:37 PM
B2FiNiTY's Avatar
What kind of thing do I need? I have the header off the car and I have no socket that will fit over it because the plastic connector is holding it down. The one on the cat seems very difficult also.
Old Jun 21, 2002 | 12:43 PM
Grumpy Old Man
I think its called and O2 sensor socket or something. I read somewhere that its a pain if you try and go at it with a wrench...Go to the store they allways know what I am talking about when I am looking for a part.
<---walks into store, "I'm looking for that thing-a-magiggie(various hand motions here) that turns that other thing?"
Salesman-"oh thats in 4 on the right side"
B2FiNiTY's Avatar
Default Re: How do I remove the 02 sensor? (ReBornGSR)
Ok. You just twist it off with the socket right?
Old Jun 21, 2002 | 12:46 PM
Tommy_Gunns's Avatar
Unplug the sensor, take the cat off the car, put the cat on a vise or something similar, twist that sensor off with an open wrench or monkey wrench.
Old Jun 21, 2002 | 12:47 PM
B2FiNiTY's Avatar
Default Re: How do I remove the 02 sensor? (Tommy_Gunns)
I already have the header off the car. The 02 sensor is stuck on there. I will try a vise grip sunday and see if that works. Where do you grab it?
Old Jun 21, 2002 | 12:48 PM
At the bottom where the hex is. for the vise, I'm talking about one that attaches to a table or bench...so the header/cat is stationary while you wrench on the O2.
Or you can just get a friend to hold it while you twist that **** off.
so you removed the cat O2 without any problems?
[Modified by Tommy_Gunns, 3:51 PM 6/21/2002]
Old Jun 21, 2002 | 12:49 PM
B2FiNiTY's Avatar
My cat is still connected the b-pipe. I am going to drop the whole b-pipe with the cat because the bolts are on too tight.
Old Jun 21, 2002 | 12:51 PM
disordeR's Avatar
yeah it's a hex head. just take a wrench and twist it off. BTW, if you are installing a carsound, i hope you took that off first, because the cat-bolts to the b-pipe are one (*%&$ to take off. with the header still on the block, you can prob get the required torque needed to get those bolts off, if not, TAKE OFF your b-pipe and torque those suckers off. it'll save you lotsa time.
good luck with the header install, i just installed my JDM 4-1 on tuesday.
EDIT: bah, you beat me to it already B2.
installing your Type One header right? give us a review when you're finished
[Modified by disordeR, 1:55 PM 6/21/2002]
Old Jun 21, 2002 | 12:56 PM
B2FiNiTY's Avatar
Default Re: How do I remove the 02 sensor? (disordeR)
Thanks man. My car is out of comission right now until I can get this done. I plan on dropping the b-pipe with the cat because the bolts are just WAY too tight. Here's what I have done so far:
1) header off the car
2) 1 bolt off the cat
3) both 02 sensors still on
4) guys on h-t are great
Old Jun 21, 2002 | 12:59 PM
Jason's Avatar
don't bother w/ a socket...just use an open ended wrench
squirt it w/ some WD-40 and let it soak for a while
Old Jun 21, 2002 | 01:00 PM
Default Re: How do I remove the 02 sensor? (Jason)
That's what I said
-Tommy who now understands how B2 got that high post count...don't use IM's, neat!
Old Jun 21, 2002 | 01:01 PM
B2FiNiTY's Avatar
My biggest allen wrench goes up to 17mm, do I need something bigger? I believe thats the size...not sure though.
Old Jun 21, 2002 | 01:02 PM
Allan wrench? You mean open ended wrench?
Old Jun 21, 2002 | 01:03 PM
B2FiNiTY's Avatar
Yeah my bad. Haha
Old Jun 21, 2002 | 01:04 PM
Willard's Avatar
adjustable wrench + hammer =
using l00b will make the wrench slip... so wipe the sensor off before you try to remove it.
Make sure the wrench is on tight and tap the wrench with the hammer untill she comes out.
use antizeeze when putting the sensor into another header.
the sensor is VERY expensive so use caution
Will
Old Jun 21, 2002 | 01:06 PM
B2FiNiTY's Avatar
Default Re: How do I remove the 02 sensor? (Willard)
Thanks for all the help so far guys. H-T is the best
Old Jun 21, 2002 | 01:07 PM
disordeR's Avatar
WD-40 = your friend.
Old Jun 21, 2002 | 01:09 PM
B2FiNiTY's Avatar
Right now, I'm using duralube...As seen on TV!
Old Jun 21, 2002 | 02:07 PM
reefer_bob's Avatar
Yep... soak it with some good penatrating oil, then get yourself one of these:
I don't like using a hammer, just cause I don't like to put too much impact on the sensor... they aren't the most robust of pieces...
Oil + Proper Socket + 1/2" ratchet + cheater bar = removed O2 Sensor...
4drteg54321
Jan 27, 2009 01:28 PM
cvc323
12
Nov 17, 2004 11:46 AM
JDMDC5888
Mar 25, 2004 02:36 PM
B16A2
12
Oct 27, 2002 06:43 PM
