oil pressure guage install
Old Apr 7, 2003 | 04:16 PM
Yellb16crxsi's Avatar
Default oil pressure guage install
do any of you know where i can buy one of those parts that go inbetween your block and your oil filter to make installing an oil pressure gauge easyer and has anyone had any experience with these.
thanks
Old Apr 7, 2003 | 04:48 PM
DeepSi's Avatar
Default Re: oil pressure guage install (Yellb16crxsi)
oil sandwich filter feed lines. you can get them from Greddy and Golden Eagle Manufactuer.
Old Apr 8, 2003 | 06:05 PM
Default Re: oil pressure guage install (DeepSi)
has anyone used one of these?
Old Apr 11, 2003 | 06:52 AM
ttt
Old Apr 11, 2003 | 11:39 AM
psi420's Avatar
Any Hardware store with fittings.
Your block comes BSP, which is very similar to NPT.
I always re-tap the block, takes about 30 seconds.
Put grease on tap to pull out shavings.
Old Apr 11, 2003 | 12:20 PM
nadc2's Avatar
Default Re: oil pressure guage install (psi420)
http://www.mcmaster.com ... they have all the parts you are looking for.. If you are located in socal, stop by tmr and they can make you some steel braided line as well
Old Apr 11, 2003 | 04:20 PM
cajnatc's Avatar
Default Re: oil pressure guage install (HecticRhythms)
Summit sells oil filter relocator kits. You can try that or you can get an Earl's performance metric to an tee, some hose, and split it so that you can still have your oil sending hooked up.
_gurusan_
Dec 20, 2005 10:41 AM
9hatch6
17
Apr 24, 2005 04:08 PM
mike93eh
Mar 26, 2005 03:01 PM
DR. ON POINT
Sep 22, 2002 06:08 PM
mugenracer
Aug 8, 2002 10:38 PM
