How much boost can a b18c1 handle safely?
Old Apr 7, 2003 | 04:09 PM
1hottEG6's Avatar
Default How much boost can a b18c1 handle safely?
Was just curious on how much boost a stock block would handle with the right fuel management?
TIA
Old Apr 7, 2003 | 04:14 PM
weakGOODJunKieS.com's Avatar
Default Re: How much boost can a b18c1 handle safely? (1hottEG6)
TIA
i asked this same question but for a b18b. under 12 psi.
Old Apr 7, 2003 | 04:16 PM
1hottEG6's Avatar
Default Re: How much boost can a b18c1 handle safely? (FrostWhiteDC4)
did u get an answer from anyone?
Old Apr 7, 2003 | 04:19 PM
hitekper4mance's Avatar
Don't forget. It's also depending on how hard you drive the car. Another thing to consider is if you run higher boost... even with proper fuel management...your valves will probably go also. I would tell you to run around 8 for safety but I am sure you can run more. Don't forget about detonation and knock with 91 octane.
https://honda-tech.com/zerothread?id=453840
[Modified by FrostWhiteDC4, 5:20 PM 4/7/2003]
Old Apr 7, 2003 | 04:53 PM
dfoxengr's Avatar
23Lbs...
Old Apr 7, 2003 | 06:34 PM
MikeMAN's Avatar
with horrible tuning 0 psi
with good tuning 20psi+
mike
Old Apr 7, 2003 | 08:29 PM
Snail Tuning's Avatar
Default Re: How much boost can a b18c1 handle safely? (MikeMAN)
12psi max then u usually need to upgrade your map sensor.
im running 7psi daily soon to be 10psi daily once i get all my leaks fixed
Old Apr 7, 2003 | 10:06 PM
MikeSarr_GSR's Avatar
Default Re: How much boost can a b18c1 handle safely? (bmcc72)
It would depend on what your definition of safe is. .75psi (NA) can still blow engines
Old Apr 7, 2003 | 10:09 PM
RangerDan's Avatar
Default Re: How much boost can a b18c1 handle safely? (MikeSarr_GSR)
With minor precuations 7lbs all day.
Heres a question. How much juice can you throw at a B18c with 11:1's
AssHammer
Jan 21, 2011 10:56 PM
Rooftop voter
Feb 13, 2009 05:53 PM
electric_rex
Sep 24, 2004 06:21 AM
chattownrexer
May 20, 2004 07:15 AM
slowcivic
Dec 14, 2001 10:12 AM
