Help! I broke a header bolt...
Old Apr 7, 2003 | 03:35 PM
ophdehEEzY
Guest
Posts: n/a
Default Help! I broke a header bolt...
Whats the easiest way to fix it? There is about .25" to .50" left on the stud. TIA
Old Apr 7, 2003 | 04:05 PM
Kataku2K3's Avatar
Default Re: Help! I broke a header bolt... (ophdeheezy)
With that much thread left you should be able to get a small pipe wrench on there which is what I would use... If not then you can drill a small hole in the end of the snapped stud, get an extractor, and screw it out... After that just buy a new stud or take one off a spare motor and you'll be set... Good Luck
Old Apr 7, 2003 | 08:22 PM
B18C2_sedan's Avatar
Use vise scrips of use a easyout. A mavhine shop you have a easyout. try heating it up first. That makes things easyer.
Old Apr 7, 2003 | 08:41 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm willing to bet it was the bolt closest to the intake tube, right? That one always breaks, as it did on my car. I just left it, no problems. I will have to remove my front bumper and radiator in order to drill out, since there is no room for a drill otherwise.
Old Apr 7, 2003 | 08:57 PM
b19coupe's Avatar
Default Re: Help! I broke a header bolt... (PatrickGSR94)
90 degree drill. Or pull the head.
Old Apr 7, 2003 | 09:01 PM
tilt's Avatar
Interesting... mine broke off too. And yeah I just left it as is, no probs.
Old Apr 7, 2003 | 09:42 PM
NiiS's Avatar
Blah! who needs header bolts anyway, just a stupid vacuum
I just assume get that **** out right away, even though there isnt a huge possibility of having cold air pass through...The last thing you want to do is burn a valve
Old Jul 17, 2003 | 04:18 PM
dwnthehatch's Avatar
Default Re: Help! I broke a header bolt... (sinister)
Did you ever get it out? I just pulled the heat shield off of the exhaust manfold on my gsr swap I just got from IAS and noticed two nuts were missing, one bolt was snapped and there is some sort of sealant all over the gasket. I left Larry Jr a message but I doubt he will do anything about it.
Here's some pics:
Old Jul 17, 2003 | 07:04 PM
quick's Avatar
* B A N N E D *
get easy out
Dc2_ShowStopper
Honda CR-V & Element
15
Apr 9, 2013 02:53 PM
Mishako129
Aug 18, 2012 12:08 PM
acmoc
13
Dec 20, 2008 11:12 AM
BeesDA6
Jul 17, 2003 04:44 PM
