obd 2 b18b into 92 cx
Old Apr 7, 2003 | 11:35 AM
b18bcx's Avatar
Default obd 2 b18b into 92 cx
I posted this on the hybrid forum but didn't get any feedback.
I can't search on the archive files, so I figure you guys can help me out.
what do I need to do to put an obd2 b18b into a 92 cx?
Do I have to use 00 integra wiring harness, or I can just use my stock one?
What motor mounts should I use?
What do I have to do to keep it obd2?
Thanks.
Old Apr 7, 2003 | 07:08 PM
b18bcx's Avatar
Default Re: obd 2 b18b into 92 cx (b18bcx)
somebody has to know this.
Old Apr 7, 2003 | 07:12 PM
Who Said's Avatar
keep it OBD I...why go OBD II?
Old Apr 7, 2003 | 07:14 PM
b18bcx's Avatar
Default Re: obd 2 b18b into 92 cx (super-dooper fast)
because it was on my friends 99 LS.
BackSideSA's Avatar
no, you just need an obd1 LS ecu...the P75 to get the obd2 motor to work in your obd1 car
Old Apr 7, 2003 | 07:18 PM
JV's Avatar
JV
Who?
I'm gonna make this quick...
Here are the mounts:
You can retain the OBDII LS harness:
Run an OBDI LS ECU and the swap will be plug and play.
AS far as a full conversion to ODBII. I know somebody on here has done it, maybe they will chime in with the info. HTH alittle...
Old Apr 7, 2003 | 07:22 PM
b18bcx's Avatar
Default Re: obd 2 b18b into 92 cx (HybridHackBatch)
hybridhackbatch, are you running an obd2 ls on your hatch?
How hard was the installation and wiring?
so, what i need is the p75 obd1 ecu and stock cx harness.
What about the mounts?
Old Apr 7, 2003 | 07:26 PM
wickedxboi's Avatar
use integra mounts
Old Apr 7, 2003 | 07:27 PM
nsxmatt's Avatar
Umm, I believe he just put two big pics with most all the info you need
Old Apr 7, 2003 | 07:33 PM
b18bcx's Avatar
Default Re: obd 2 b18b into 92 cx (nsxmatt)
oh, im sorry, I clicked only 2 sec later after he posted.
Old Apr 7, 2003 | 08:01 PM
1990hondaHF's Avatar
Does the OBD-2 LS engine have more HP then the OBD-1 engine?
Old Apr 7, 2003 | 08:24 PM
sshaikh01's Avatar
Default Re: obd 2 b18b into 92 cx (1990hondaHF)
not really.
i believe its only two horses
[Modified by sshaikh01, 11:25 PM 4/7/2003]
Old Apr 8, 2003 | 03:29 PM
b18bcx's Avatar
Default Re: obd 2 b18b into 92 cx (sshaikh01)
thx JV for the pics.
what about the injectors and distributor?
Is it ok if I use Integra ones?
Old Apr 8, 2003 | 03:40 PM
JV's Avatar
JV
Who?
It's all plug and play as long as you use the LS wiring harness. No need to swap distributors or injectors...
moz92
Jan 5, 2007 03:57 PM
EKtypeRhaTcH
May 10, 2005 10:46 AM
chinners10
Mar 21, 2003 03:49 PM
drewlee
Jan 6, 2003 01:53 PM
