obd 2 b18b into 92 cx
I posted this on the hybrid forum but didn't get any feedback.
I can't search on the archive files, so I figure you guys can help me out.
what do I need to do to put an obd2 b18b into a 92 cx?
Do I have to use 00 integra wiring harness, or I can just use my stock one?
What motor mounts should I use?
What do I have to do to keep it obd2?
Thanks.
Thanks.
Re: obd 2 b18b into 92 cx (b18bcx)
I'm gonna make this quick...
Here are the mounts:
You can retain the OBDII LS harness:
Run an OBDI LS ECU and the swap will be plug and play.
AS far as a full conversion to ODBII. I know somebody on here has done it, maybe they will chime in with the info. HTH alittle...
Re: obd 2 b18b into 92 cx (HybridHackBatch)
hybridhackbatch, are you running an obd2 ls on your hatch?
How hard was the installation and wiring?
so, what i need is the p75 obd1 ecu and stock cx harness.
What about the mounts?
Re: obd 2 b18b into 92 cx (1990hondaHF)
Does the OBD-2 LS engine have more HP then the OBD-1 engine?
i believe its only two horses
[Modified by sshaikh01, 11:25 PM 4/7/2003]
thx JV for the pics.
what about the injectors and distributor?
Is it ok if I use Integra ones?
EKtypeRhaTcH
05-10-2005 10:46 AM
