b18c1 into 2000 CX..what throttle cable?
I did some searching, but couldn't really find a good answer.
What did you use, the CX throttle cable, or a GSR cable?
HTH
Jason
Check out my post from last week. Had the same quetion. Mines a 93, but I think the thread will help you:
https://honda-tech.com/zerothread?id=455183
I'm not a hybrid guru or anything... but you should need the GSR throttle cable, as the CX is too short. The I/M of the GSR puts the throttle body at a weird position and the cable needs to be a certain length to reach around... dont' forget the cable brakets on the manifold...
X2
X2
HXMan
May 8, 2003 08:20 PM
