.how hard is it to replace valve guide seals??
Old Apr 6, 2003 | 09:46 AM
civicracer1993's Avatar
Default .how hard is it to replace valve guide seals??
i have a d16z6. do i have to take the head off to do this?
Old Apr 6, 2003 | 09:50 AM
hybridmoose's Avatar
Default Re: .how hard is it to replace valve guide seals?? (civicracer1993)
Yes you will have to disassemble the entire head,(ie remove the cam and valvetrain)
Old Apr 6, 2003 | 10:03 AM
NirSpec1's Avatar
you will have to take the head off and completely take it apart. Plus the seal should be pressed in by a machine shop.
peace
Old Apr 6, 2003 | 11:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: .how hard is it to replace valve guide seals?? (NirSpec1)
Don't you have to heat up the head and chill the valve seals to get them in, similar to installing piston and rod wrist pins?
Old Apr 6, 2003 | 11:34 AM
leadfoot78's Avatar
Default Re: .how hard is it to replace valve guide seals?? (PatrickGSR94)
I think you are talking about the actual valve guides and the original poster it talking about valve stem seals.
Old Apr 6, 2003 | 01:01 PM
real9999's Avatar
Default Re: .how hard is it to replace valve guide seals?? (leadfoot78)
Valve seals can be removed and installed with the head on the car. It requires compressed air, a rail type spring compressor, valve stem seal remover, and installer. Dealers do it this way all the time. If you try it without the right tools, it's very difficult. Or, you can pull the head.
Plenty of info in the archives..... but you can't search them right now.
Valve guides are an entirely different story.
Tom
[Modified by real9999, 10:03 PM 4/6/2003]
80 dolla crx hf
Sep 8, 2014 01:28 PM
SynTeg
Jan 16, 2005 05:12 PM
biggie2005
Feb 26, 2004 06:23 PM
MisterB
Jun 4, 2003 09:31 PM
Space Boy
May 30, 2002 12:46 AM
