bleeding the block??
Old Apr 5, 2003 | 12:59 PM
Buckshot's Avatar
Default bleeding the block??
where is the bleeding screw to let the air out for coolant.
i know where it is on a gsr block but its not on the same place for a itr block
Old Apr 5, 2003 | 01:05 PM
2k1_ITR_0736's Avatar
Default Re: bleeding the block?? (Buckshot)
by the thermostat housing, its a 12mm, should be by the upper radiator inlet to the block, (assumed highest point) of the coolent.
Old Apr 5, 2003 | 01:14 PM
Buckshot's Avatar
Default Re: bleeding the block?? (2k1_ITR_0736)
thanks a lot
Old Apr 5, 2003 | 01:26 PM
n/p
Old Apr 5, 2003 | 05:10 PM
Volcom's Avatar
or you can leave the raditor cap off and start the car. Then lightly squeeze the raditor hoses to get all the bubbles and air out. I had a bleeder valve on my 94 RS but broke it off when installing my thermostat. I went to Acura and they sold me a 98 and above part but Acura started making the part without the valve (I'm guessing too many people like me were braking them) The service guys told me just to squeeze the hoses and you'll be fine. It worked great.
Old Apr 5, 2003 | 06:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: bleeding the block?? (Volcom)
Thermostat housing? My bleeder screw is where the upper rad. hose attaches to the engine, but the thermostat housing is on the lower rad. hose. Is the GS-R different from other cars? My friend's Civic coolant bleeder screw is also on the upper rad. hose.
Old Apr 5, 2003 | 06:58 PM
mickey513's Avatar
Yup, I too broke the bleeder valve on the water outlet housing when changing coolant on my 94 Integra. I bought a new one from Acura and it didn't have the bleeder valve. I asked the Part guy and he said it was necessary. All newer models Integra didnt' have them either.
Old Apr 5, 2003 | 10:34 PM
Buckshot's Avatar
Default Re: bleeding the block?? (mickey513)
so just squeeze the radiator tubing...the top one or the bottom?
Old Apr 6, 2003 | 09:28 AM
Volcom's Avatar
top tube.
dunkd
Jan 24, 2010 09:02 AM
integraboosted
Oct 13, 2007 09:20 PM
CO_CReX
Apr 29, 2007 06:44 PM
93(Civic)EG6
Nov 8, 2006 08:48 AM
The_Head
Feb 26, 2002 09:00 AM
