Pre-Swap distributor question, 2001 B20z diz, 96 DX harness
Old Apr 5, 2003 | 04:53 AM
b20guy's Avatar
Default Pre-Swap distributor question, 2001 B20z diz, 96 DX harness
Tomorrow I'm doing my swap, finally.
I just have one question. The distributor wiring. My DX harness has two plugs, a 2 wire one, and I think 7 on the other. The 2001 CRV distributor has one plug with 8 wires. So where do I go from here? Am I to just match up the colors, or should I check Helms and verify the functions of each. Problem is I don't have the Helms for the DX.
Can someone maybe clarify the colors of the DX and their function so I get this right the first time? Wish me luck
B20z, skunk2 im, gsr with quaife, B&M FPR, P75 OBD2 in a 96 DX hatch
Old Apr 5, 2003 | 05:17 AM
eg6ajk's Avatar
Default Re: Pre-Swap distributor question, 2001 B20z diz, 96 DX harness (b20guy)
yes just replug the distirbutor
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Old Apr 5, 2003 | 08:11 PM
b20guy's Avatar
Default Re: Pre-Swap distributor question, 2001 B20z diz, 96 DX harness (eg6ajk)
thanks dood
Old Apr 6, 2003 | 04:43 PM
b20guy's Avatar
Well I got the b20 in there today. I have the majority of the wiring left to be done and the axles. I ran into a roadblock though. The guy who sold me a LS intermediate shaft solde me one for an automatic i guess. The three bolt holes are the right pattern, but the angle is wrong up against the block. So I guess I need to look for one asap.
I can't get the right side axle in there. It's about 1 inch or so away from being butted up against the tranny. Anyone have any suggestions to make this easier?
I hooked up all the distributor wires except the blue one for RPM output. The b20z distributor doesn't have that wire on the distributor. What do I do with this? Will my tach get a signal from somewhere else?
And I found out that I need a new fuel line. The dx fuel line lets fuel in on the side of the thread, the ls/gsr one on the end of the thread, or any i just confused.
Luckily I have a little beater car to get me to work, while I figure this out.
used2baracer
Mar 5, 2011 05:38 AM
GREY_EK96
12
Jul 20, 2005 06:57 PM
cartracin6
Nov 22, 2004 02:07 PM
xvietxkhmerxboix
Sep 15, 2003 10:15 AM
