how could i make my car redline higher?
Old Apr 3, 2003 | 06:19 PM
sivortech's Avatar
Default how could i make my car redline higher?
I have a b16a engine with the si computer and i was just wondering how i could get it to redline at 8000 instead of 7000
Old Apr 3, 2003 | 06:26 PM
sslude's Avatar
Default Re: how could i make my car redline higher? (sivortech)
why would you wanna do that. im sure the b16 doesnt make power that high. but if you got cams, you could get a higher redline with valve springs and retainers. or you could get a chip, or a whole new ecu. but its really pointless without cams beucase there is a certain point in your power band where you stop making power adn you dont wwanna go too far past that
Old Apr 3, 2003 | 06:39 PM
RICE POLICE SIP's Avatar
Default Re: how could i make my car redline higher? (sslude)
get a chipped ecu or vtec controller i think allows you to adjust it... not sure
eg6ajk's Avatar
if you have the B16A swap then Si (p28 ecu) will simply not cut it indeed. you can chip the ecu or get already chipped version or stock P30 variety.
check my sig for different options
Old Apr 3, 2003 | 06:40 PM
sslude's Avatar
Default Re: how could i make my car redline higher? (92boostn'hatch)
vtec controller only allows you to fine tune your fuel and set vtec cross-over points, not make your rev higher.
Old Apr 3, 2003 | 10:07 PM
andrewasf77's Avatar
yea sure, go ahead and raise you rev limit without upgrading anything else. then come back in here and post a question like "What is the ticking sound coming from my engine?"
Old Apr 4, 2003 | 04:46 AM
Lsos's Avatar
The b16 makes its peak power at 7600rpm and was deemed by the factory to redline at 8000rpm. It will last turning 8000rpm for quite some time. He doesn't need to upgrade anything but the ecu.
Old Apr 4, 2003 | 06:11 AM
rustyeleio's Avatar
My very humble opinion...
I feel that raising the redline on a stock engine is a little risky because the stock valve springs were only meant to go so fast before you get some valve float. Even if your car theoretically makes usable power above the stock redline doesn't mean that the stock engine will handle that rpm. Engine balancing, spring rates, and other things become questionable beyond the recomended redline. You're not going too far past the stock limit, so maybe it would be ok, but I'd wait until you hear back from several people who say they have done exactly that with no problems. Good luck.
lsveg6
Oct 15, 2005 04:35 PM
808State
Jun 21, 2005 08:08 AM
MADEINIRAQ
Jan 23, 2003 01:06 PM
xXx Justin xXx
17
Jun 29, 2002 02:35 PM
MXPX
Jul 4, 2001 02:25 PM
