Engine Temp Guage is stuck on HOT!!
My engine temp gauge is shooting up to hot even though my engine is completely cold...Is there a senor on the engine some where i can look at to see if it is loose or is my Si gauge acting up? This is happening to my 96 EK hatch with a 99/00 SI gauge cluster.....i have a 96 EK with a 96 GSR motor and 99 SI gauge cluster
[Modified by CM-R, 1:12 PM 4/3/2003]
Check your thermostat. Might be stuck closed, thus causing your engine to overheat. Eitherway, take it out and try driving the car.... if your temp stays down, then you know you need to replace the thermostat. If not, and you still have the same problem, then it's something else but you've at least taken away the most common problem out of the equation. BTW, driving w/out the thermostat won't hurt anything... just takes the car longer to warm up.
Can you please show me or explain to me in detail how the gauge or plug looks like so i can check it out? Thanks alot for the help
[Modified by CM-R, 12:18 AM 4/4/2003]
CivicMatt94
Jul 21, 2014 08:33 PM
electric-boost
Dec 11, 2006 08:37 PM
CM-R
Apr 2, 2003 12:56 PM
