How to tell auto from manual PG7 ecu?
Old Apr 1, 2003 | 09:30 PM
photonjedi808's Avatar
Default How to tell auto from manual PG7 ecu?
How do you tell the difference? Does it even matter?
Old Apr 2, 2003 | 04:01 AM
zCivic's Avatar
Default Re: How to tell auto from manual PG7 ecu? (photonjedi808)
it will give a CEL of 19 which is Lock-Up Solenoid Valve.
Old Apr 2, 2003 | 12:14 PM
Default Re: How to tell auto from manual PG7 ecu? (zCivic)
Is there anyway to tell before installing?
Old Apr 2, 2003 | 12:26 PM
zCivic's Avatar
theres some #'s in the bar code but I'm unsure on how those go. Sorry
Old Apr 3, 2003 | 10:42 AM
ok thanks anyway
would my car run good with the auto ecu?
Old Apr 3, 2003 | 12:24 PM
JAMinCiViC's Avatar
This is from Hondata.com
"Automatic ECUs are designated with a 5 as the second to last digit in the bar code (after the 'A'). e.g. 37820 P28 A51. "
[Modified by JAMinCiViC, 3:25 PM 4/3/2003]
Old Apr 3, 2003 | 02:24 PM
mbsi's Avatar
Default Re: How to tell auto from manual PG7 ecu? (JAMinCiViC)
I believe the 5 speed ecu's end with an 8. My old crx si ecu ended with A080.
So 5 auto, 8 standard. Please correct me if im wrong
Old Apr 3, 2003 | 03:16 PM
turbohf's Avatar
Default Re: How to tell auto from manual PG7 ecu? (mbsi)
the car will run fine with a code 19 drove for months like that with my ZC, hell the car did its best NA time with that ECU...
Old Nov 24, 2003 | 01:14 PM
zccrx's Avatar
your wrong i followed these directions when buying my pg7 and the one i bought doesnt even have a 5 in it anywhere and it was an automatic but i got it for 50$ and it still works but now i get cel 19 all the time
Old Nov 24, 2003 | 01:17 PM
FourthGenHatch's Avatar
I thought ECUs said "A/T" or "M/T" on them. I thought I remembered seeing that.
Old Nov 24, 2003 | 01:36 PM
USDM 4G VTEC's Avatar
Default Re: How to tell auto from manual PG7 ecu? (FourthGenHatch)
thats on the internals close to the chip
not all had them
u wanta good answer
go to http://www.pgmfi.org/
vy3tnamezz
Engine Management and Tuning
10
Sep 25, 2009 08:35 PM
gt3hurman
Apr 20, 2005 10:50 AM
EJCivJdM93
Jan 26, 2005 03:48 PM
your username here
Nov 29, 2003 04:58 PM
absolut b18
Aug 3, 2003 12:38 PM
