92 integra cable tranny..... will it accept an 00 itr clutch and flywheel?
no
on the ground and tried fitting my old stock clutch on it. Might have been a 91 though.
Trey
If it's a YS1 92-93 GSR trans, the answer is yes.
The issue is the size of the input shaft, and the YS1, uses the larger "hydro" input shaft.
It should work. I am using an ITR flywheel on my 92 LS. I belive the splines are different from 91 below and 92 above.
89-91 are Small Spline, 92+ are Large Spline and are the same as B-Series Hydro.
Suprdave
Suprdave
I used the ITR clutch and FW when I swapped the R motor in my '92 a few years ago, and I used the YS1 tranny. Worked perfectly.
DA is best
Transmission & Drivetrain
Dec 30, 2010 11:10 AM
EF9-CIVIC
Jun 6, 2007 04:48 PM
DOHCarp
Mar 14, 2003 09:04 AM
