Apexi D series turbo kit
Old Mar 31, 2003 | 07:36 PM
SOHC_MShue's Avatar
Default Apexi D series turbo kit
i just saw this on the groupbuycenter for 1200. I can't believe how cheap it is on there. i was thinking of buying a used greddy kit, but this sounds even better. What would i need to run the stock boost with this kit? i know i would need an intercooler and bov. Also does it come with any fuel management? and if not is there anyway a cheap greddy blue box would work because thats probably all i could afford for a while. also what kind of numbers could i expect on the stock boost? thanx guys. I haven't really heard much info on this kit before.
-Matt
Old Mar 31, 2003 | 09:03 PM
turbod16y8's Avatar
Default Re: Apexi D series turbo kit (SOHC_MShue)
check otu this site http://www.wabe.net/silum/turbo.html
Old Apr 1, 2003 | 05:29 AM
SOHC_MShue's Avatar
Default Re: Apexi D series turbo kit (turbod16y8)
so do you think i could use the greddy blue box for fuel managment or wouldn't that be enough?
Old Apr 1, 2003 | 06:42 AM
civicudesire's Avatar
For the price of the apexi kit you would be dumb as hell to get the greddy. I dont know how apexi can sell that kit so cheap because a fewmonths ago it was retailing for $2200 without intercooler. Actually 2 weeks ago a friend of mine picked the apexi kit up with intercooler for $2600 and that was a really good deal. So if i were in your situation I would be picking one of these up asap. If money is tight BUY A BOV before a intercooler. Without the intercooler you will be able to run stock boost.
Old Apr 1, 2003 | 06:54 AM
SOHC_MShue's Avatar
Default Re: Apexi D series turbo kit (civicudesire)
i'm only worried because my budget is tight. I would have enough for bov, but the intercooler might be out of my range and i'm would run unintercooled, but it is getting close to summer now and i am worried about the excess heat which will probably slow me down a lot.
Old Apr 1, 2003 | 07:14 AM
Night_Minx
Guest
Posts: n/a
dont boost a car on a tight budget.
Old Apr 1, 2003 | 07:20 AM
SOHC_MShue's Avatar
Default Re: Apexi D series turbo kit (Night_Minx)
could i use maybe a 1g dsm sidemount intercooler? also what about the fuel managment? would the blue box work or not?
Old Apr 1, 2003 | 09:43 AM
SOHC_MShue's Avatar
Old Apr 1, 2003 | 09:57 AM
K you wanna go cheap? Find your self a 1gen dsm bov the metal ones not the plastic. You can pick one up nomore then $50. Then find yourself a starion intercooler for under $150 and your done except for some modifications. Wanna go cheaper pick your self up a audi or dsm side mount intercooler for $50-$75. For fuel system I say go with a vortech fmu/inline fuel pump and a fpr. I mean thats really budget boost right there. If you stay stock boost with the apexi kit and get yourself a bov I really think your going to be fine in the summer. You will lose hp without the intercooler when its really hot though but I really dont see any side effects other then detonation but if your stock boost you should be k.......
Old Apr 1, 2003 | 09:58 AM
Daniel's Avatar
the sidemount will work. just make sure you have some kind of opening for air to hit the intercooler. not sure about the blue box. i want to say yes, but i don't positively know. it probably would, though, as long as you keep the boost around 5-7 psi. Those things make you run really rich.
Old Apr 1, 2003 | 10:06 AM
SOHC_MShue's Avatar
Default Re: Apexi D series turbo kit (Daniel)
does anyone else know about the blue box?
Old Apr 1, 2003 | 12:26 PM
domslude's Avatar
how good is this kit versus the f-max/rev hard and stuff?
sean
Old Apr 1, 2003 | 03:00 PM
glagola1's Avatar
I'm running the apexi kit on my B18B and have been for several months now. The kit made 240hp and 227tq on a very untuned 10psi. I've had the greddy kit and it is a piece of dog **** compared to the Apexi. That IHI turbo is a very hi tech turbo that will flow as well as a T3 and puts down better numbers than an 18G.
The blue box will work beautifully as long as you don't go past 7psi and you retard your base timing a few degrees.
This is the cleanest kit I've ever seen. A true bolt on.
Old Apr 1, 2003 | 03:18 PM
jkan2005's Avatar
Default Re: Apexi D series turbo kit (glagola1)
Did you just move the apex turbo to a B series manifold? As far as i know apex doesn't even make a B series turbo kit. Do you know how many CFM's the IHI turbo makes. I'm asking cause i'm gonna to LS this summer and i want to move my apex kit from my d16 to the B18b
Old Apr 1, 2003 | 05:40 PM
Civic_95_Si's Avatar
They make JDM kits for B16B and B18CR.
Old Apr 1, 2003 | 05:57 PM
TurBoXBirD16's Avatar
Default Re: Apexi D series turbo kit (Civic_95_Si)
i would go with the Apexi even though the price is higher...
but with the Ball bearing turbo, the nice intercooler and pipes...
i would get the apexi... even i have the greddy now.....
i haev seen so many apexi with
Old Apr 1, 2003 | 06:10 PM
Happyman's Avatar
Default Re: Apexi D series turbo kit (TurBoXBirD16)
Would it fit a d16y8?
Edit: Nevermind I just read the GB and it does.
[Modified by Happyman, 10:11 PM 4/1/2003]
Old Apr 1, 2003 | 06:26 PM
leadtrum's Avatar
Default Re: Apexi D series turbo kit (Happyman)
the b series kit should be available any moment now from what i heard. some dude up north is running it on his teg or something. i forgot the shop but they already have kits in stock if you're interested. its the same turbo as the sohc but i imagine that with proper tuning it'd produce a nice power upgrade for a street setup.
imo. fit and finish is A+
Old Apr 2, 2003 | 07:03 AM
domslude's Avatar
Default Re: Apexi D series turbo kit (leadtrum)
so basically the apex is two tumbs up eh?
sean
Old Apr 2, 2003 | 07:06 AM
domslude's Avatar
Default Re: Apexi D series turbo kit (domslude)
one would still have to buy the bov, fuel managment, and all the other stuff, so it would be more expensive then say a maxrev. If i'm not worried about customizing, ie I don't need a true bolt on, is it still that great of a kit, when you spend substatially more then the maxrev, but then again, I could get the new chip that this one guy on here is making. I have been following up on that, and then I could program my fuel maps and stuff my self, would take some careful learning, and time at the dyno wheel though......... decisions, decisions, decisions.
Old Apr 2, 2003 | 08:55 AM
Charlie Moua's Avatar
yes , yes, yes.....>! damn it Apexi turbo it with the BB turbo is the ***** and top knoch quality.....did you read my other post about this yet!
Old Apr 2, 2003 | 12:08 PM
domslude's Avatar
Default Re: Apexi D series turbo kit (Charlie Moua)
no, where is it at?
Old Apr 2, 2003 | 12:30 PM
no, where is it at?
https://honda-tech.com/zerothread?id=461064
here you go it should work!
Old Apr 2, 2003 | 01:26 PM
I called to order it today but they won't take my American Express, even though its listed on the cards they take. I hate bad business.
Old May 13, 2003 | 10:53 AM
RacerBoy's Avatar
Where the hell is the groupbuy for this? I want one!
civic5483
Mar 21, 2004 05:13 PM
pg_thao
Apr 17, 2003 08:29 PM
RICE POLICE SIP
Apr 13, 2003 03:31 PM
CzanSOHC
Sep 11, 2002 04:22 PM
skhonda
Sep 5, 2002 11:46 AM
