Yet another question thats been asked a thousand times... GSR & Boost??
Old Mar 31, 2003 | 05:48 PM
92HB_HB's Avatar
Default Yet another question thats been asked a thousand times... GSR & Boost??
okay okay,
I tried the search button but didn't really find a clear answer.. I might be gettting a stock gsr motor/trans soon to replace my turbo LS motor/trans.. My question is, whats the suggested and safe boost level that I can run on the stock gsr motor b4 i have to worry about rebuilding the internals?? I dont plan on doing that until maybe next yr..
thanks in advance...
Old Mar 31, 2003 | 07:06 PM
92HB_HB's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (92HB_HB)
NO one knows??
Old Mar 31, 2003 | 07:20 PM
falcongsr's Avatar
What is this crap?
depends on the setup honestly.
Old Mar 31, 2003 | 07:32 PM
Daniel's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (falconGSR)
yep. You can boost 3 psi and have the motor blow on you or you can run a tuned setup at 8 psi and be fine. depends on the setup, how well you take care of everything, and how good your fuel delivery is. if it's crap or non-existant, don't expect anything to last too long.
Old Mar 31, 2003 | 07:40 PM
92HB_HB's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (Daniel)
alright i forgot to add some important factors:
system includes:
hondata2b tuned of course
rc440's
255 walbro
aemfpr
inline manifold
t3t4e 63 ar 60 trim
93 octane
rps clutch
3" exhaust
am i missing anything else?
Old Mar 31, 2003 | 07:47 PM
falcongsr's Avatar
What is this crap?
yeah, an intercooler. personally i'd run 8psi on that setup. but thats just me.
Old Mar 31, 2003 | 09:10 PM
b16ahybrid's Avatar
have some fun go for 10psi if it's tuned properly (looks as though you have the rite equiptment) you should be fine runing 10psi
Old Mar 31, 2003 | 09:17 PM
SlamMan's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (b16ahybrid)
B-series block can handle up to 10 psi with good fuel management like EMS or hondata (no tweak boxes)
Old Mar 31, 2003 | 09:49 PM
I Like Boost's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (SlamMan)
setup sounds good, run anything between 7-10psi you will be fine.
Old Mar 31, 2003 | 11:39 PM
lilxvtecxpwr's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (IMPULSE B18C-T)
yea, i'm running 10psi and no problems yet *knock on wood
Old Apr 1, 2003 | 01:31 AM
GOLDBERG's Avatar
Default Re: Yet another question thats been asked a thousand times... GSR & Boost?? (lilxvtecxpwr)
how much boost could you run with forged rods and pistons??? oh WITH a nice size intercooler..
Old Apr 1, 2003 | 05:49 AM
Xscream's Avatar
Boost, I wax GSRs with my LS
Old Apr 1, 2003 | 07:34 AM
boosted hybrid's Avatar
If you prep the block right, you can push 400whp+ on race gas. I ran a b16a head, gsr bottom end, arp head studs, cometic thicker headgasket (9:1 comp) and a race engineering block guard. On pump I ran 14lbs everyday, on race gas I was pushing 19lbs. This was on a 60-1 t3. All stock internals. It can be done. It helps when you can tune yourself, but if you have a good tuner anything is possible.
crazykamper
Jan 26, 2009 04:44 PM
WillieB
Jul 2, 2006 10:09 PM
teddy_dc2
Mar 1, 2006 09:08 AM
KillaB18
Jun 1, 2005 03:30 AM
integralsdriver29
Jan 20, 2005 07:59 PM
