please help: my car dose this in 3rd gear @7k rpm:::::
Old Mar 30, 2003 | 08:14 PM
b16powwer's Avatar
Default please help: my car dose this in 3rd gear @7k rpm:::::
i have a 91 crx si w/b16a1
when i am driving in 3rd gear only, after 7k rpm, the car will not rev any more, it takes a few seconds so it can rev higher then 7k rpm in 3rd, is it my spark plugs or is it my psi, i have my aem fpr set at like 42psi, the car did not do this before,
these are the mods i have:
b16a1, ported and polished head w/itr intake valves, itr springs and retainers, stock block, aem short ram intake, thermal catback ss exhaust, power core race cat, jg 4-2-1 header, itr trottte body, itr intake manifold, itr cams, skunk 2 cam gears, clutch net clutch and flywheel, walbro 255lph fuel pump, aem fpr, aem fuel rail, vtec controller, chipped pro mugan ecu to redline at 9300 rpm, vtec set at 6000 rpm
Old Mar 30, 2003 | 08:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: please help: my car dose this in 3rd gear @7k rpm::::: (b16powwer)
only third? or 4th and 5th too?
if you are lean, the load is less in 1st and second. due to torque multiplication. you maay be experiencing a lean out on the top end. make sure your fuel delivery is up to the task.
b16hybridsol
Engine Management and Tuning
Aug 16, 2012 09:11 AM
DelSolKid
Sep 12, 2004 03:15 PM
b16powwer
Feb 2, 2003 12:06 PM
