Stroking a B16????
Old Mar 30, 2003 | 04:23 PM
lsvtec4door's Avatar
Default Stroking a B16????
has any1 stoked a b16a to 1.9 liters or higher,if so whats the highest stroke u can do with the lowest compression or can u stroke it and put low compression pistons in it.....
and does any1 have any suggestions on whats the best motor to do for turbo
Old Mar 30, 2003 | 05:26 PM
dfoxengr's Avatar
Default Re: Stroking a B16???? (lsvtec4door)
i like GSRs best for turbo... biggest you can stroke a B16A to is probly 2.12L
Old Mar 31, 2003 | 04:18 AM
Charlie Moua's Avatar
please refer to search! I know there are about 3 post in the last 2 week about it!
Old Mar 31, 2003 | 07:45 PM
TimoneX's Avatar
New User
Stroke the motor to 81.7mm w/ the B17 crank and bore it to 86mm with GEs zilla sleeves. You'll end up around 1.9l and you can still rev it as it'll still have a good r/s ratio of 1.62:1. Stroking the b16 much more than that takes away from what makes the B16 special to begin with, it's near perfect geometry.
Old Mar 31, 2003 | 10:00 PM
10K2HVN's Avatar
Default Re: Stroking a B16???? (TimoneX)
"near perfect *geometry*" but still too small of a displacement...i just noticed that i think i may have a problem with the B16...
Old Apr 1, 2003 | 04:54 AM
TimoneX's Avatar
New User
Default Re: Stroking a B16???? (10K2HVN)
What do you mean "too small of a displacement"? An 86mm B17 would be 1891cc. That's almost 60cc more than the overhyped LS/Vtec frankenmotor and far more reliable, and since it's all factory Vtec there are no oil lines "taped" on to fail or just look ugly. Depending on cams, redline, breathing, and the all important tuning I bet you could get that motor near 200WHP. I'd take that motor over either of the popular frankenstien setups.
Old Apr 1, 2003 | 09:50 AM
Katman's Avatar
he's probably referring to the "torqueless wonder" a B16A is because of the 1600cc stroke..
Old Apr 1, 2003 | 06:19 PM
TimoneX's Avatar
New User
Default Re: Stroking a B16???? (Katman)
Yeah but after you make the B16's 77mm crank into a paper weight the B16 is not so bad anymore. A B18C would still be preferable IMO, but naturally costs more too.
Old Apr 2, 2003 | 12:00 PM
Katman's Avatar
....yes, obviously.
Old Apr 2, 2003 | 09:28 PM
TimoneX's Avatar
New User
Sure seem to be alot of questions surrounding this "obvious" topic.
Old Apr 5, 2003 | 12:32 AM
10K2HVN's Avatar
YEAH! Drop that crap piece and pick up a B18C!!!
Old Apr 5, 2003 | 11:08 AM
TimoneX's Avatar
New User
There's nothing crappy about the B16, cept perhaps the crank.
Old Apr 8, 2003 | 10:06 AM
PupaScoopa's Avatar
Good luck finding a B17 crank...
Old Apr 8, 2003 | 10:11 AM
stevel's Avatar
Default Re: Stroking a B16???? (PupaScoopa)
instead of stroking the b16 why don't you just have it bored out to 1.8L and then you keep that nice r/s ratio. That's what I'd love to do to my b16.
s
Old Apr 8, 2003 | 01:38 PM
riceboyEFsi's Avatar
i have 1 ill take $100. 4 it needs a polishing
Old Apr 8, 2003 | 03:39 PM
TimoneX's Avatar
New User
Default Re: Stroking a B16???? (h00sier)
what is the r/s ratio?
1.62:1 w/ the B17 crank. They're not all that hard to find, and they're worth the effort if you're determined to stick with the B16. Remember the B17 crank in the B16 also gives you a .5 boost in static compression. It's a good deal.
Old Apr 19, 2003 | 08:46 PM
dyg2001's Avatar
Do you know anybody who has done this? It sounds good on paper.
xelhefe
14
Sep 4, 2011 01:37 AM
jizzer671
Mar 3, 2006 12:50 AM
blazin
Aug 27, 2002 08:13 PM
ricodemus
Aug 9, 2002 06:18 PM
turbohf
May 10, 2002 01:52 PM
