HELP my R making weird SOUNDS
Old Mar 30, 2003 | 03:28 PM
itr1244's Avatar
Default HELP my R making weird SOUNDS
cluth/tranny? problems
-when it engage from dead stop some times it makes loud click sound.
-when it disengage at low speed it make the clicking sound again
-when i slow down while in gear (very low speed like almost stoping speed) it makes the same sound.
suspension problem(wheel bearing???)
-when it speeds up around 40km so like 25mph and over it starts making the noise like wiiiiing wiiiiiiiiiiiing wiiiiiiiiiiing wiiiiiiiiiing and it gets faster as i speed up and gets slower as the speed deresses.
what the hell's wrong with my R?
Old Mar 30, 2003 | 03:29 PM
yellow blur's Avatar
Default Re: HELP my R making weird SOUNDS (itr1244)
Axle? Does it click when you turn at low speeds?
[Modified by yellow blur, 4:29 PM 3/30/2003]
Old Mar 30, 2003 | 04:06 PM
itr1244's Avatar
Default Re: HELP my R making weird SOUNDS (yellow blur)
no.. not when i turn.. if it does it's probably the cv joint gone
but i am sure it's coming somewhere near tranny/cluth
Old Mar 30, 2003 | 06:23 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
mine clicks as well when I engage the clutch. Not all the time, but probably a few times a week. I thought it was a spring loose or ready or break, but no far no problems...
Old Mar 30, 2003 | 06:52 PM
Dr Pooface's Avatar
Default Re: HELP my R making weird SOUNDS (RealTypeR)
Mine makes the same clicking sound as yours does, on and off load. It has been making it for a year or so now. If you find out what it is let me know.
Old Mar 30, 2003 | 09:16 PM
.RJ's Avatar
.RJ
Default Re: HELP my R making weird SOUNDS (typeR0059)
throwout bearing
Old Mar 30, 2003 | 09:41 PM
Willard's Avatar
Purchase two new cv joint nutz (32mm versions) and replace the ones that are on the car (134ft/lbs IIRC).
That fixed my clicking sound for about 2 months.
[Modified by Willard, 1:41 AM 3/31/2003]
Old Mar 30, 2003 | 10:14 PM
92TypeR's Avatar
FSAE
Default Re: HELP my R making weird SOUNDS (Willard)
I had a clicking sound when I engaged/disengaged the clutch on my ATS tranny...I narrowed it down to the slave cylinder...just clicks at the end of the release.
Old Mar 30, 2003 | 11:41 PM
hYpE-R-29's Avatar
i had the same problem, mine was the clutch when downshifting, made a clicking noise...I thought it was the spring loader bolt that connected my JDM header to my cat...but it wasent, the dealer opened my clutch and saw a spring popped out and ordered me a new clutch for free....Problem solved!!!.. check yours!!
Old Mar 31, 2003 | 01:23 AM
itr1244's Avatar
Default Re: HELP my R making weird SOUNDS (hYpE-R-29)
so anyone got this fixed?
gnccracer20
Jan 7, 2009 05:13 PM
J.nguyen
Suspension & Brakes
30
Sep 26, 2006 12:39 PM
Sean Juan
Feb 1, 2006 11:55 AM
Ph0nK
Aug 22, 2004 11:51 AM
VTEC-DA
Nov 7, 2002 04:27 AM
