Apex VAFC or Fields Vtec...MINI ME
I was wondering if I could still install the VAFC or fields using a non vtec ecu. How would I be able to do this? Anyone have instructions on how to? I dont want to run vtec with an rpm switch cuz the fuel maps.
So what you want to do is use non-VTEC ecu on a VTEC motor, and let the VAFC handle all the VTEC duties?
I don't know the answer, I'm just clarifying your question because it seems like you're getting some different answers based on people's interpretation of what you asked.
Top portion of the motor is a vtec head. Bottom is my D16Y7 block. I have a rpm activated switch which I did not install yet because of the fuel problems that it would create. Trying to see if I can install the VAFC only or a fields to take care of everything. I can also use the rpm switch if I have to.
cookci
Apr 6, 2004 01:24 AM
