Valve Adjustment
Old Mar 30, 2003 | 11:44 AM
MCP486's Avatar
Default Valve Adjustment
Ok it's the first time I have pulled off the valve cover since acquiring my Type R in December. Now I am pissed, because I was able to fit .009 on my intake side. That's far past the .003-.005 the manual says it should be. I intend to tighten them, but is there anything else I should check for wear that may be causing this? I know that if the valves get too tight they will damage the seats, but are there any serious effects from having them too loose, besides a loss in performance, such as burning valves, etc?
Thanks,
Matt
Old Mar 30, 2003 | 11:58 AM
VTHokie's Avatar
Default Re: Valve Adjustment (MCP486)
i thought clearance on a type r was .006 on intake and .007 on exhaust
[Modified by VTHokie, 4:01 PM 3/30/2003]
Old Mar 31, 2003 | 12:27 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Valve Adjustment (VTHokie)
Does the wheel have to be off to turn the crankshaft?
Old Mar 31, 2003 | 12:30 PM
CPR's Avatar
CPR
Default Re: Valve Adjustment (95 Gizzer)
No it doesnt. Just turn your steering wheel as fart left as it will go and you should have enough space to get a rachet in there.
Old Mar 31, 2003 | 12:44 PM
VTHokie's Avatar
Yeah i took it off cause i thought it would be a pain in the *** to do it with a big wheel in the way. But i dunno, i have never tried it with the wheel on, maybe i'll do that next time.
Old Mar 31, 2003 | 02:31 PM
Aaron M's Avatar
i did mine yesterday, taking the wheel definatly helps if your weak like me and need to crawl inside the wheel well to get enough leverage
make sure u use jack stands if you do that
Old Mar 31, 2003 | 04:15 PM
frogsr's Avatar
Default Re: Valve Adjustment (SilverB18C1)
if you guys are having a hard time cranking the crankshaft, you can just take out the sparkplugs beforehand. makes it much easier as the 'compression' is lost through the sparkplug holes.
Old Mar 31, 2003 | 04:37 PM
98cwitr's Avatar
Default Re: Valve Adjustment (frogsr)
quick question: how much of a difference would .002 in. make power wise? How often should you check your valve clearances?
Old Mar 31, 2003 | 09:17 PM
frogsr's Avatar
Default Re: Valve Adjustment (98cwitr)
service manual says to inspect every 15k miles or so and adjust as necessary. make sure that the engine is cold when checking and adjusting.
Old Mar 31, 2003 | 10:32 PM
tC_Dragon's Avatar
so how did your valve adjust go? werk out well?
Old Mar 31, 2003 | 10:54 PM
Aaron M's Avatar
Default Re: Valve Adjustment (pdcdragon)
yea, i bent my .007 feeler guage though, which didnt help move things along
Old Apr 1, 2003 | 12:27 AM
tC_Dragon's Avatar
sorrie to hear that... when scott (integobsession) gets his car back... u wanna help us do ours? haha... all help is greatly appreciated. I'll buy you some
Old Apr 1, 2003 | 12:48 AM
Aaron M's Avatar
ill help, i dont drink though
EDIT: the only thing i drink is PHO
[Modified by SilverB18C1, 1:50 AM 4/1/2003]
Old Apr 1, 2003 | 12:51 AM
threatcon13's Avatar
New User
so, are we gonna have a valve adjustment mini meet? im down.
Old Apr 1, 2003 | 12:52 AM
Aaron M's Avatar
Default Re: Valve Adjustment (Threatcon13)
[Modified by SilverB18C1, 1:50 AM 4/1/2003] so, are we gonna have a valve adjustment mini meet? im down.
u ***
EDIT: threatcon is my dawg, he knows im playin, yea we should have a meet. whos gonna bring the PHO though?
[Modified by SilverB18C1, 1:54 AM 4/1/2003]
Old Apr 1, 2003 | 01:48 AM
tC_Dragon's Avatar
there's a pho joint bout a mile from my place. Some people argue that the pho isnt all that good but i like it... but they're egg rolls are probably the best anywhere.
so i'm down for a minimeet for sure.
Old Apr 6, 2003 | 11:58 AM
illusion's Avatar
why even bother with the crank bolt? i just leave my car in gear and push it forward or backwards to spin the engine..
lordbucanero
Sep 11, 2012 05:51 PM
Bulli Kid
Dec 8, 2007 07:04 PM
jdm169
Jan 24, 2003 05:36 PM
HavokB18
18
Jan 7, 2003 08:50 PM
raene
Jun 27, 2001 10:45 PM
