How To: Fixing broken strut bar stud
tools needed: Furious uncle whose has a good aim with a hammer + a BFH(big ******* hammer) and a strong sharp object between the uncle and the bolt
step 1: hammer it out
it should take a couple of hard hits to make it look like that.
step 2: apply new screw
Leave the broken studs to show the new studs what will happen if they decide to break on me again
[Modified by TypeR 599, 11:59 PM 3/29/2003]
Wouldn't it have been better to drill them out instead of hammering them out? Looks like the reinforcement plate isn't reinforcing anything anymore...
i think that plate serves more as a washer. once i find some washers that will fit that i'll use them.
I still would have drilled it out. Using a bigger & bigger drill until there wasn't ant bolt left. then dremeled the Bolt head off.
Then replace the Bolt, even put a weld trac on it.
Your a wild-man.
Your a wild-man.
