Strut tower bar squeaks
Old 03-25-2003, 12:02 PM
CXHatchback's Avatar
Default Strut tower bar squeaks
Anyone have this problem? I put a Neuspeed one on and it squeaks a lot during turns and accelerations. Can I just grease it up underneath?
Old 03-25-2003, 12:30 PM
FifthGearOnline's Avatar
Default Re: Strut tower bar squeaks (CXHatchback)
strut bar or sway bar???
edit: cuz arnt the neuspeed STRUT bars 1 piece?
[Modified by FifthGearOnline, 3:30 PM 3/25/2003]
Old 03-25-2003, 02:44 PM
Default Re: Strut tower bar squeaks (FifthGearOnline)
Yeah that's the wierd part. I think it makes noise where it bolts to the top of the struts.
[Modified by CXHatchback, 4:14 AM 3/26/2003]
Old 03-25-2003, 02:54 PM
Loco Honkey's Avatar
Tighten the nuts more.
Old 03-25-2003, 02:56 PM
kommon_sense's Avatar
Default Re: Strut tower bar squeaks (Loco Honkey)
I agree. If it squeaks, then it is shifting. Also are you sure that it is the strut bar? It stiffened up the chassis, so it may actually be something else that is squeaking.
Old 03-25-2003, 02:57 PM
Lord Helmet's Avatar
I've never had a problem with my neuspeed strut bar. are you sure it's the strut bar considering its a one piece. better check you bushings on your suspension front and back. older cars tend to squeak quite a bit from deterioting suspension bushings.
Old 03-25-2003, 07:17 PM
Default Re: Strut tower bar squeaks (sleeperciv)
ok maybe I'll try tightening it up more. It was a really tight fit to put it on since it was from an EK, but I dont' know if that matters. I thought I torqued it down pretty well but maybe not. Also, there are probably a bunch of other things squeaking, so it may not be that. I think my camber kit and/or balljoints are doing it. But this extra squeak started happeining as of today when I installed the bar
Old 03-25-2003, 07:25 PM
elwood's Avatar
My guess is that when you took off your nuts to put the tower bar on,
the a arm's droped a little and there is some crap between the a arm
and the thing were the shock goes. Causing it to squeak.
Old 03-25-2003, 08:54 PM
Default Re: Strut tower bar squeaks (d15dude)
The neuspeed bar I have bolts to the shock's upper mount bolts.
Old 03-25-2003, 08:57 PM
acydphryck's Avatar
one word...well two actually
WD-40
don't know if that's 2 words or not...
Old 03-25-2003, 10:26 PM
elwood's Avatar
I have the same one on my car.....was your car jacked up
when you put it on?
Old 03-26-2003, 04:39 AM
when you put it on?
No it wasn't, just on the ground. Should it have been jacked up?
And I think I'll try the wd-40 today
Old 03-27-2003, 07:16 AM
PupaScoopa's Avatar
Default Re: Strut tower bar squeaks (acydphryck)
[quote]one word...well two actually
WD-40
[/quote}
Yep, definitely one word. Hyphenated.
MechEng
05-29-2011 06:49 PM
dohcdelsol
06-01-2004 06:06 PM
BlueG3Teg
12-09-2001 02:19 PM
Quick Reply: Strut tower bar squeaks
