Quick help on install of AEM CAI
Old Mar 29, 2003 | 06:51 PM
Ideal R's Avatar
New User
Default Quick help on install of AEM CAI
Hi all, I need some quick help here. I just installed my AEM CAI. I started my engine and saw CEL, then I realize I forgot to connect the sensor on the TB. I quickly turned my car off and connected the sensor. When I start the engine again, the CEL is still there. Can anyone give me some light here? Thanks!
Old Mar 29, 2003 | 07:00 PM
VTEC-DA's Avatar
Default Re: Quick help on install of AEM CAI (Ideal R)
Did you connect the sensor back onto the intake tube itself also? There should be no way a CEL comes on with an intake, unless you forgot to plug a sensor.
Old Mar 29, 2003 | 07:16 PM
acuracing's Avatar
Reset the ECU.
Old Mar 29, 2003 | 07:21 PM
Ideal R's Avatar
New User
Default Re: Quick help on install of AEM CAI (acuracing)
Can you tell me how to reset it?
And why I need to reset it? Because I forgot to plug in the sensor the first time?
Thanks!
Old Mar 29, 2003 | 08:23 PM
98itR484's Avatar
Why did you even unplug the sensor??? last time i checked the sensor doesnt need to be unplugged to put the CAI on. Anyhow, just take off the positive battery cable for a minute (not exactly a minute dont count down ) then replace it. CEL should go away. But before you make the CEL disappear, if you know how to check the code, check it to see if it is the sensor or not.
Old Mar 29, 2003 | 08:47 PM
gohandbz8's Avatar
Default Re: Quick help on install of AEM CAI (98itR484)
another way to reset the ECU is just to remove the fuse for the ECU. Give it about 1 minute then plug it back in. Should go away without a problem
Old Mar 29, 2003 | 08:50 PM
Ideal R's Avatar
New User
Default Re: Quick help on install of AEM CAI (gohandbz8)
Got it, thanks!
P.S.: I just unplug the sensor cause it is "sort of" getting out of my way. But I must say it is not necessary and I think I won't do that again next time!
Old Mar 30, 2003 | 07:37 AM
Ideal R's Avatar
New User
Default Re: Quick help on install of AEM CAI (typeR0059)
It is the under-hood fuse #47 if I remember correctly. It is a 7.5A fuse.
Old Mar 30, 2003 | 07:39 AM
Dropspeed's Avatar
To reset the ECU and eliminate the CEL open the underhood fuse box near the battery. There is a 7.5 amp fuse in the back row, refer to the cover to verify that it is the Radio Back-up fuse. Remove the fuse and reinstall it, you don't have to wait just pull it and put it back in. The CEL will be cleared.
Matt Jensen
ddrakiotes
Honda Civic (2006 - 2015)
Sep 6, 2007 12:42 PM
magicguy
11
May 17, 2007 12:34 PM
TheHater
Jan 15, 2003 10:27 AM
N~FaMouSKhMerBoi
Sep 18, 2002 12:44 PM
