Type R valves... B16 Valves... any difference ?
Old Mar 29, 2003 | 05:39 PM
2 0 3's Avatar
Default Type R valves... B16 Valves... any difference ?
yes i ran a search...
i have a knicked valve in my b16 head, im looking for a factory exhaust valve ot replace it, a friend of mine has all his stock vlaves form his type r head, since he replaced wiht aftermarkets... can i use one of his stock exhuast valves ? are the specs the same between b16 and b18c5 ? i know most parts in the head are... please some one clarify this for me
or if nayoen has a sotkc b16 valve ill take that!
Old Mar 29, 2003 | 05:43 PM
BlueR's Avatar
Default Re: Type R valves... B16 Valves... any difference ? (allmotorDA6)
i believe type R valves are lighter...contact len @ baranco acura
Old Mar 29, 2003 | 06:50 PM
VTEC-DA's Avatar
Default Re: Type R valves... B16 Valves... any difference ? (BlueR)
I think he means construction wise. I am pretty sure that all b16/b17/b18c5 valves are the same designs, only difference being weight/strength etc. But I think the shape and everything regarding interchangableness (word?) are the same.
Old Mar 29, 2003 | 07:14 PM
92TypeR's Avatar
FSAE
Default Re: Type R valves... B16 Valves... any difference ? (VTEC-DA)
I believe that the ITR valves are bigger...at least on the intake side.
Also the valve seats are different.
Old Mar 29, 2003 | 11:04 PM
shivers's Avatar
si/gsr/itr exhaust valves = the same. I just checked the part #s last week. itr/ctr intake valves are lighter which allows for 300 more rpm rev limit.
Old Mar 29, 2003 | 11:09 PM
Jowee's Avatar
Default Re: Type R valves... B16 Valves... any difference ? (ajm_00Si)
Autopedia had an article on the ITR and I believe the ITR valves are 33% lighter yet have the same strength as regular valves.
Old Mar 30, 2003 | 01:40 AM
b19coupe's Avatar
The B16 head and the Type-R head are made from the same casting, PR3. They both use the same exhaust valves. The Type-R intake valves are different: they are narrower near the head of the valve to promote better flow. I have two B16 heads that have Type-R intake valves installed on them, no problems. If you want to use your friends ITR exhaust valves, you will be fine. Have them installed professionally-get the seats redone and have the valves reground, your basic three angle valve job.
Old Mar 30, 2003 | 11:25 AM
2 0 3's Avatar
Default Re: Type R valves... B16 Valves... any difference ? (b19coupe)
thanks so much guys, gona do that... 3 angle.... so i should be fine
Old Mar 30, 2003 | 11:27 AM
sgT's Avatar
sgT
you only need to have the seats redone on the intake side since the seat angle is
different. the exhaust valves and seats are identical.
Old Mar 30, 2003 | 02:46 PM
Griffin 279's Avatar
Type R EXHAUST VALVES are the same Part number as the B16 Exhaust Valves. The Intake side is Different, Larger and Lighter.
Old Mar 31, 2003 | 09:57 AM
2 0 3's Avatar
Default Re: Type R valves... B16 Valves... any difference ? (Griffin 279)
thanks so much guys im dropping the valve off today, all the valve seats were re done anyway so this on will be as well, so everyhting looks like it will be perfect, thansk for the help again.
Old Mar 31, 2003 | 01:33 PM
sgT's Avatar
sgT
how many times does this have to be repeated for pete's sake.....
the intake valves are NOT LARGER, they are the same size.
Sr420Det
Mar 20, 2009 01:25 AM
Sr420Det
Mar 19, 2009 05:57 PM
bluegdx16
Feb 17, 2005 06:59 PM
1hottEG6
Apr 5, 2003 05:14 PM
2 0 3
Mar 30, 2003 06:50 AM
