Clutch noise?
Old Mar 29, 2003 | 04:42 PM
Mr Boston's Avatar
Default Clutch noise?
I've been noticing that my R makes this slight SHHHHHHH noise when I'm engaging or disengaging the clutch at idle in gear or outta gear and its a little bit louder the more revs I'm at when I'm driving on the street. Does anyone know what it could be?
[Modified by Integra Type R, 10:08 PM 3/29/2003]
Old Mar 29, 2003 | 04:56 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Clutch noise? (Integra Type R)
stock or aftermarket clutch?
Old Mar 29, 2003 | 05:06 PM
Mr Boston's Avatar
Default Re: Clutch noise? (RealTypeR)
Stock clutch
Old Mar 30, 2003 | 12:12 AM
Mr Boston's Avatar
Anyone?
Old Mar 30, 2003 | 01:16 AM
reverie's Avatar
I have that problem on my GSR. It screeches while engaging into gears, right?
After some research, I believe it's due to the release bearing of the clutch being loose, something or another. No big deal, it seems, but it can be annoying. I haven't been hearing it much for a while now, though.
Old Mar 30, 2003 | 02:47 PM
quikRthanU's Avatar
my R makes a noise when engaging
what ive found is that it usually happens after it rains for that day and the day after it
just my R tho maybe not yours
Old Mar 30, 2003 | 03:06 PM
Jack Black's Avatar
That was the first sign that the throwout bearing was going on one of my old cars. If the sound gradually gets louder over time, that's probably it.
Old Mar 30, 2003 | 03:20 PM
markpaco's Avatar
Mine does that. It is normal if it is the same thing that I have. My other ITR motor and other cars that I've changed the clutch on/driven have that too.
Old Mar 30, 2003 | 07:07 PM
ITR#132's Avatar
Default Re: Clutch noise? (markpaco)
hey mines does that too.
Are you sure it is normal as mines didnt do it before (58,000 miles on stock clutch, 2 CM, and 1 ACT). I thought it was the release bearing (and Crappy CM clutch->less than 5000 miles) and since I was dropping the tranny I put in a new clutch and release bearing, pilot bearing and its still there Anyone else have an idea?
[Modified by ITR#132, 8:56 PM 3/30/2003]
Old Mar 30, 2003 | 07:18 PM
Mr Boston's Avatar
Default Re: Clutch noise? (ITR#132)
The werid thing is the last ITR I drove about a 7 months ago had the same Shusssshing noise. Sounds like something is dragging?
Old Mar 30, 2003 | 07:23 PM
accord-euro-r's Avatar
New User
My gsr also has that noise. Every time when I engage in 1st gear, there comes the sound "Eeeeeeeee". The sound will goes off after the 1st gear totally engaged. Will it damage the transmission?
DeeJaaY209
14
Sep 15, 2013 10:40 PM
bbrian
Jun 11, 2013 05:07 PM
93delslow315
May 7, 2011 09:59 AM
avex
Oct 26, 2003 09:54 AM
Mr Boston
Mar 29, 2003 09:19 PM
