how to retard timing for boost?
Old Mar 29, 2003 | 04:34 AM
rudebwoy's Avatar
Default how to retard timing for boost?
I want to know how can I retard my timing on a b16, using adjustable cam gears, and how would know how much to retard?
Old Mar 29, 2003 | 04:37 AM
AudioXtremes's Avatar
Default Re: how to retard timing for boost? (rudebwoy)
just search for uberteg and check out his chip. It retards the timing 1 deg for every 1lb of boost.
Old Mar 29, 2003 | 07:52 AM
rudebwoy's Avatar
Default Re: how to retard timing for boost? (AudioXtremes)
I have a jun chip installed, I want to replace it, so how can I manually retard timing?
Old Mar 29, 2003 | 07:54 AM
Flamenco-T's Avatar
cam timing or ignition timing ?
Old Mar 29, 2003 | 08:55 AM
b16ahybrid's Avatar
doing that would retard your cam timing, you need to retard your ignition timing for boost. If you don't have a stand alone then your second best option is to buy a msd btm to retard your timing relevent to boost. Or you can just retard your timing by turning your distributor, stock is 16 degrees so depending on how much boost your runing set it to about 14 up tp about 7psi and 12-13 for more boost. Doing it that way is not the best for power because it throws all your timing off (cam,ignition, injector,etc)......
xcountrirunr
Dec 1, 2004 08:57 AM
Btothe3rdDegree
Nov 12, 2004 04:53 PM
CRXLST
Oct 27, 2004 09:45 PM
BEV@GSCMotorsports
May 14, 2004 10:00 AM
808eg6
Jun 24, 2002 07:52 AM
