is the tial supposed to make sound when under no boost?????
Old Mar 28, 2003 | 01:38 PM
evoeone's Avatar
Default is the tial supposed to make sound when under no boost?????
well i am venting my tial to the atmosphere, and i thought that you would only hear your regular exhaust during regular cruising and that the tial only opened at max boost, now its pretty loud under regular driving, and damm loud when it opens.
is it supposed to be like this?
running just the spring, hooked the side port to the turbo and left the top one open since i am not running a boost controller. everything ishooked up right, just probaby wont hear what i want to,
and do you lose power when re routing it? i heard maybe like 2-3 horses,
Old Mar 28, 2003 | 02:27 PM
drewspeed's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (evoeone)
At what Psi (or bar) is the spring set at? (ie. what size is the spring) Once you hit that psi or bar it will open and definitely be louder.
Could your WG gasket have ripped already?
[Modified by drewspeed, 3:27 PM 3/28/2003]
Old Mar 28, 2003 | 02:45 PM
b18cx's Avatar
sounds like you left the specisl washer/gasket out. My friend did that andhad the exact same problem. It looks like a metal ring that gets sandwiched inbetween the wastegate and the manifold when you bolt the wastegate down.
Old Mar 28, 2003 | 08:09 PM
B18Flip's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (b18cx)
see...I Told you!
[Modified by B18Flip, 12:10 AM 3/29/2003]
Old Mar 28, 2003 | 08:20 PM
evoeone's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (B18Flip)
i put it in and its still dumb loud, was supposed to get the 9.43 spring but i guess they screwed up and sent me the 7 psi spring,
its ok, i just kinda wish that you hear the regular exhaust and right at 7 psi it opens, more of a surprise
Old Mar 28, 2003 | 11:29 PM
turbopanda's Avatar
did anyone ever find a decent solution to the tial wastegate gasket problems? the best I ever got was with no gasket at all.. still leaked a tiny bit, but was much better than having broken gaskets every 2-3 weeks
Old Mar 28, 2003 | 11:46 PM
*Boostwerks*'s Avatar
iits ok, i just kinda wish that you hear the regular exhaust and right at 7 psi it opens, more of a surprise
This is normal.
The valve is slowly opening during boost, causing the louder sound even before full boost. It's not like the valve will just suddenly open right at the springs boost rating. This is why adding certain MBC's, or a EBC, will lessen the spool up time. They keep the valve completely closed until the specified boost pressure is reached.
[Modified by Bryson, 1:46 AM 3/29/2003]
Old Mar 29, 2003 | 12:43 AM
blufke's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (turbopanda)
would no gasket and just some copper gasket maker do very well?
Old Mar 29, 2003 | 06:03 AM
TurboDC4's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (blufke)
Get a deltagate gasket with firering. They are 8 bucks.
Old Mar 29, 2003 | 07:16 AM
evoeone's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (TurboDC4)
so an mbc can be somewhat a solution?
i mean it makes maaad noise even driving under vacuum, not whining about it, i like it, but wish the "opening" was more of a surprise. nah mean?
Old Mar 29, 2003 | 11:16 AM
Yes.
Just make sure the valve is a type that is closed until the full boost rating you set it too.
Dawes Device and TurboXS are 2 good choices
[Modified by Bryson, 1:16 PM 3/29/2003]
Old Mar 29, 2003 | 06:53 PM
evoeone's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (Bryson)
so i'll try a dawes devices next paycheck
i just wanna run the spring for now, so should i just turn the MBC to minimum setting right?
wg sound is cool , but even during soft cruising at 15 vacuum it gets annoying, love when it opens but sometimes it gets annoying, cool then, thanks for the tips, later
Old Mar 29, 2003 | 06:58 PM
evoeone's Avatar
i know this sounds weird, but with my internal wastegate and 2.5 dp and test pipe and 2.25 catback i was running 9-9.5 psi and it felt quicker, now with the 7 psi spring it feels slower and with a full 3" exhaust
now i know there is a diff between teh 2.5 psi, but it feels like it takes longer to spool is what i'm saying now,
please tell me that an MBC will cure this to.
how does the mbc help my problem of wg (pre)venting- exhaust and spool up? can someone explain, thanks
[Modified by evoeone, 10:58 PM 3/29/2003]
Old Mar 30, 2003 | 06:24 AM
evoeone's Avatar
im sure an electriv boost controller would work better right?
well since i dont have profec B money, i'll deal with a chep mbc till then
Old Apr 1, 2003 | 07:38 PM
swpdb16's Avatar
I have the same problem with my tial, i installed it today and when the car is idling there is exhaust coming out of the dumptube is that supposed to be normal. I am missing the metal sleeve that goes into the wastegate that little ring, i do have the gasket though. its a 4psi spring can anyone help me out, can you buy this part seperately if not im screwed, or its SOMEWHERE in my messy *** garage
Old Apr 1, 2003 | 07:54 PM
boostaholic's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (swpdb16)
Nope, the wastegate should be completely closed at idle. You shouldn't feel any exhaust coming out the dumptube.
Old Apr 1, 2003 | 08:13 PM
skhonda's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (boostaholic)
No there should be no exhaust coming out at idle, however i had the same exact problem with mine at first. Take it off carefully, and make sure the metal ring is seated correctly in the wastegate. Next, put it back on the manifold very carefully, it helps to push the wastegate down so the ring is squished onto the manifold, making sure there is no visible space between wastegate/gasket/manifold, and bolt it back up. That should take care of it venting while under idle, because it fixed it for me. hope this helps some.
[Modified by skhonda, 11:16 PM 4/1/2003]
Old Apr 1, 2003 | 08:28 PM
swpdb16's Avatar
Default Re: is the tial supposed to make sound when under no boost????? (skhonda)
Everything would be working accordingly if i wouldnt of lost the fawkin metal ring that goes under the wastegate, DAMN!! Anyone know where i can get one of these
Thanks for the answers
supabang
Aug 19, 2007 08:12 AM
crazyimport
Jul 14, 2004 06:08 PM
Snafu-Si
Mar 31, 2003 02:08 AM
NCSTIdriver
Dec 9, 2002 07:22 AM
DOHCarp
Jun 29, 2002 11:30 AM
