In what HP range do you need to warrant sleeves?
Search is still down. I am wondering at what HP levels I am looking at to begin to need sleeves in a B18b block. I would just hate to build my motor and spend a lot of time and money on forged internals only to find out that I should have spent the extra $1500 or so for a sleeved block.
Eric
Eric
Re: In what HP range do you need to warrant sleeves? (vwluv10338)
i wouldn't think hp range so much as boost range personally
but i would think 300hp and above is warranting for at least a blockguard, better safe than sorry
Re: In what HP range do you need to warrant sleeves? (BoosterChair)
some guys run 15psi on stock sleeves at the track well tuned.
its not how much hp until you need sleeves its how much boost till you need them.
i woudlnt push over 15psi without sleeves.
Re: In what HP range do you need to warrant sleeves? (shortyz)
correct me if i wrong but i think jinxproof99 made 509hsp with stock sleeves, but id sleeve anything over 300hsp to be safe
-j
Re: In what HP range do you need to warrant sleeves? (SEX DR)
thats rite
cheezefrog also have stock sleeves
Re: In what HP range do you need to warrant sleeves? (rewsnaeht)
I would say this is a good rule of thumb.
"I would say anything over 18psi and/or 350whp i would reccomend them."
Re: In what HP range do you need to warrant sleeves? (civicudesire)
dont get sleeved untill you crack the stock ones
Re: In what HP range do you need to warrant sleeves? (metal-x)
Detonation puts massive amounts of uncontrolled pressure across the combustion chamber and cylinder. Its hard to say where the pressure is going to be applied within the combustion. If tuning is on, you dont have detonation, you dont need sleeves.
