Anyone built their own Turbo Timer?
Ive been playing with the idea of making my own turbo timer using a 555 timer in monostable and just having a toggle switch to give it vcc so you can control when you want the timer to come on(whenever current/voltage drops to near ground, thats what i need to know, Qs below).
The only things that seem somewhat difficult is picking how to have the 555 interact with the car to keep it running. What is it that is actually keeping the car on? I cant really figure out a way to have the timer interact with the car until i know how the car usually operates and knows when to turn on/off(is it voltage, current, and in which wires). if anyone has ever played around with or done this or just has any info post it, thanks.
two things.
One, you could just use a pulse timer relay, and wire that up to the ignition. I would think that this would be the simple-est. (and cheapest)
Two, I have an apexi TT that I will let go for cheap, it could save you some time...
just my two cents.
just my two cents.
J.nguyen
Sep 30, 2006 04:27 PM
